| Manually uninstalling old versions of AJDT [message #33468] |
Thu, 15 April 2004 16:10  |
I happen to be one of those ppl messing with the AJDT CVS repository.
So I just wanted to confirm the uninstallation procedure to remove the
almost final version of AJDT 1.1.7. Basically deleting the following
directories should be sufficient right?
org.aspectj.ajde_1.1.7
org.eclipse.ajdt.examples_0.6.7
org.eclipse.ajdt.ui_0.6.7
org.eclipse.aspectj_1.1.7
Omair
| Re: Manually uninstalling old versions of AJDT [message #33815 is a reply to message #33468] |
Fri, 16 April 2004 04:47  |
------=_NextPart_000_00B8_01C423A0.4348F1D0
Content-Type: text/plain;
charset="iso-8859-1"
FWIW, maybe a hint for future early-birds accessing "pre-official" =
versions: I had put (i.e. unpacked/unjar-ed) the mentioned code into a =
separate directory=20
C:\eclipse_plugins\aspectj
i.e. features into:
C:\eclipse_plugins\aspectj\eclipse\features
resulting in a directory:
C:\eclipse_plugins\aspectj\eclipse\features\org.eclipse.aspe ctj_1.1.7=20
and the plugins into:
C:\eclipse_plugins\aspectj\eclipse\plugins
resulting in directories:
C:\eclipse_plugins\aspectj\eclipse\plugins\org.aspectj.ajde_ 1.1.7
C:\eclipse_plugins\aspectj\eclipse\plugins\org.eclipse.ajdt. examples_0.6.=
7
etc.
and then just placed a "link-file" to it, i.e. a file called =
"aspecj.link" (the extension .link is important!) containing just the =
line
path=3DC:/eclipse_plugins/aspectj
into a folder "links" in the eclipse directory.
Thus, later, just removing that link-file from the links-folder and =
restarting the environment is (or at least it seems to be...) the only =
thing necessary to uninstall this version again.
Official versions (i.e. from a feature-update site) I install normally =
using the feature installation mechanism.
Michael
"Omair-Inam Abdul-Matin" <oiinamul@cs.uwaterloo.ca> wrote in message =
news:c5mpt7$mk$1@eclipse.org...
> I happen to be one of those ppl messing with the AJDT CVS repository.=20
> So I just wanted to confirm the uninstallation procedure to remove the =
> almost final version of AJDT 1.1.7. Basically deleting the following=20
>=20
>=20
> Omair
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>FWIW, maybe a hint for future =
early-birds accessing=20
"pre-official" versions: I had put (i.e. unpacked/unjar-ed) the=20
mentioned code into a separate directory </FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>C:\eclipse_plugins\aspectj</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>i.e. features into:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =20
C:\eclipse_plugins\aspectj\eclipse\features</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>resulting in a=20
directory:</FONT></DIV> =20
<DIV> </DIV></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and the plugins into:</FONT></DIV>
C:\eclipse_plugins\aspectj\eclipse\plugins</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>resulting in directories:</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2> C:\eclipse_plugins\a spectj\eclipse\plugi=
ns\org.aspectj.ajde_1.1.7</FONT></DIV>
ns\org.eclipse.ajdt.examples_0.6.7</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2> etc.</FONT ></DIV>
<DIV><FONT face=3DArial size=3D2>and then just placed a "link-file" to =
it, i.e. a=20
file called "aspecj.link" (the extension .link is important!) containing =
just=20
the line</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>----------------------</FONT></DIV>
size=3D2>path=3DC:/eclipse_plugins/aspectj</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>into a folder "links" in the eclipse=20
directory.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thus, later, just removing that =
link-file from the=20
links-folder and restarting the environment is (or at least it seems to =
be...)=20
the only thing necessary to uninstall this version again.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Official versions (i.e. from a =
feature-update site)=20
I install normally using the feature installation =
mechanism.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Cheers,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Michael</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Omair-Inam Abdul-Matin" <</FONT><A=20
href=3D"mailto:oiinamul@cs.uwaterloo.ca"><FONT face=3DArial=20
size=3D2>oiinamul@cs.uwaterloo.ca</FONT></A><FONT face=3DArial =
size=3D2>> wrote in=20
message </FONT><A href=3D"news:c5mpt7$mk$1@eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:c5mpt7$mk$1@eclipse.org</FONT></A><FONT face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> I happen to be =
one of those=20
ppl messing with the AJDT CVS repository. <BR>> So I just wanted to =
confirm=20
the uninstallation procedure to remove the <BR>> almost final version =
of AJDT=20
1.1.7. Basically deleting the following <BR>> directories =
should be=20
sufficient right?<BR>> <BR>> org.aspectj.ajde_1.1.7<BR>>=20
org.eclipse.ajdt.examples_0.6.7<BR>> =
org.eclipse.ajdt.ui_0.6.7<BR>>=20
org.eclipse.aspectj_1.1.7<BR>> <BR>> Omair</FONT> </BODY></HTML>
------=_NextPart_000_00B8_01C423A0.4348F1D0--
| Re: Manually uninstalling old versions of AJDT [message #577831 is a reply to message #33468] |
Thu, 15 April 2004 16:41  |
> Omair
Yes - I *think* that is right. Please post a reply to this group if it
works OK for you.
cheers,
Andy.
| Re: Manually uninstalling old versions of AJDT [message #577935 is a reply to message #33468] |
Thu, 15 April 2004 17:14  |
Yes, but don't forget org.eclipse.aspectj_1.1.7 under features. There is
one in plugins and one in features.
> I happen to be one of those ppl messing with the AJDT CVS repository. So
> Omair
| Re: Manually uninstalling old versions of AJDT [message #578178 is a reply to message #33468] |
i.e. features into:
7
etc.
line
Michael
>=20
>=20
> Omair
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
it, i.e. a=20
just=20
be...)=20
face=3DArial=20
one of those=20
confirm=20
of AJDT=20
should be=20
FUDForum. Page generated in 0.04100 seconds
