Home » Eclipse Projects » Eclipse Platform » Negative search
Negative search [message #330547] Fri, 01 August 2008 03:36 Go to next message
Does anyone know how (or if it is possible at all) to do a negative file
search (e.g. find all .java files that do *not* contain the word "foo")
in Eclipse?
Dimitrios
Re: Negative search [message #330548 is a reply to message #330547] Fri, 01 August 2008 03:51 Go to previous messageGo to next message
--------------090801060609010906000400
Cannot regexes do the trick? "Search => Files..." tick "regular
expression" and search for "\A[^\Qfoo\E]*\Z" while setting the file
filter to *.java.
This seems a little "overkill" for such a task, but I think this would
work as expected.
Laurent Goubet
Obeo
Dimitrios Kolovos a
Re: Negative search [message #330550 is a reply to message #330548] Fri, 01 August 2008 04:08 Go to previous message
Hi Laurent,
Thanks for your reply! I was hoping they would but I can't seem to get
them working. Instead, I've scribbled a "Negative Search Engine" by
changing the locateMatches method of (a copy of) the
org.eclipse.search.internal.core.text.TextSearchVisitor class (in case
anyone else is interested) and this seems to do the trick.
Dimitrios
laurent Goubet wrote:
> filter to *.java.
> work as expected.
> Regards
> Laurent Goubet
> Obeo
> Dimitrios Kolovos a écrit :
>> file search (e.g. find all .java files that do *not* contain the word
>> "foo") in Eclipse?
>> Cheers,
>> Dimitrios
Previous Topic:correct way to open editors of various "types" (i.e., to create an EditorInput?)
Next Topic:Minimize the editor Area does not work on all PCs ?
Current Time: Tue Jul 22 18:29:38 EDT 2025
Powered by FUDForum. Page generated in 0.06126 seconds
