| Negative search [message #330547] |
Fri, 01 August 2008 03:36  |
Does anyone know how (or if it is possible at all) to do a negative file
search (e.g. find all .java files that do *not* contain the word "foo")
in Eclipse?
Dimitrios
| Re: Negative search [message #330550 is a reply to message #330548] |
Fri, 01 August 2008 04:08  |
Hi Laurent,
Thanks for your reply! I was hoping they would but I can't seem to get
them working. Instead, I've scribbled a "Negative Search Engine" by
changing the locateMatches method of (a copy of) the
org.eclipse.search.internal.core.text.TextSearchVisitor class (in case
anyone else is interested) and this seems to do the trick.
Dimitrios
laurent Goubet wrote:
> Cannot regexes do the trick? "Search => Files..." tick "regular
> expression" and search for "\A[^\Qfoo\E]*\Z" while setting the file
> filter to *.java.
> This seems a little "overkill" for such a task, but I think this would
> work as expected.
> Regards
> Laurent Goubet
> Obeo
> Dimitrios Kolovos a écrit :
>> file search (e.g. find all .java files that do *not* contain the word
>> "foo") in Eclipse?
>> Cheers,
>> Dimitrios
FUDForum. Page generated in 0.71668 seconds
