Home » Eclipse Projects » Eclipse Platform » Way to modify text file in RCP project before build with ANT
Way to modify text file in RCP project before build with ANT [message #330538] Thu, 31 July 2008 12:53 Go to next message
Originally posted by: mircea.luchian.matrox.com
I am trying to modify a text file that contains the build data and time
before building / exporting my application. I cannot use a "custom
build" checkbox and generate a build.xml from the PDE Tools popup menu
because among teams, the physical project location changes from PC to PC.
I need to hook my ANT task into a predefined event in Eclipse and be
able to run it while keeping the default build mechanism (not the custom
one) provided in the "build" tab.
In Netbeans this was easy as I had a build.xml file that I could
customize and add a "target" tab with a predefined target name (e.g.:
post-jar, pre-init, port-init, etc.).
How can I hook a custom ANT task in a build event in Eclipse?
Mircea
Re: Way to modify text file in RCP project before build with ANT [message #330542 is a reply to message #330538] Thu, 31 July 2008 16:32 Go to previous messageGo to next message
PDE/Build supports custom callbacks in the generated build.xml.
See
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_custom_callbacks.htm
This is used during automated headless build and export. These won't
get run as part of a workspace build unless you set up an ant builder on
your project.
-Andrew
Mircea Luchian wrote:
> Hello,
> Mircea
Re: Way to modify text file in RCP project before build with ANT [message #330555 is a reply to message #330542] Fri, 01 August 2008 09:52 Go to previous message
I am interested in generating the build ID only when I export so the
link below is perfect.
Thank you,
Mircea
> See
> on your project.
> -Andrew
>> Hello,
>> time before building / exporting my application. I cannot use a
>> "custom build" checkbox and generate a build.xml from the PDE Tools
>> popup menu because among teams, the physical project location changes
>> from PC to PC.
>> custom one) provided in the "build" tab.
>> (e.g.: post-jar, pre-init, port-init, etc.).
>> Thanks,
>> Mircea
Previous Topic:Source attachments for plug-ins?
Next Topic:Following upgrade "Error: no label provider for container"
Current Time: Tue Jul 22 00:55:15 EDT 2025
Powered by FUDForum. Page generated in 0.06964 seconds
