Home » Eclipse Projects » Eclipse Platform » How do I add a preferences page programatically at run time?
How do I add a preferences page programatically at run time? [message #330517] Wed, 30 July 2008 17:17 Go to next message
Originally posted by: dlacerte.counterpath.com
I have a preference page that is added the usual way with an entry in the
plugin.xml file as in all the examples. Unfortunately this preference page
should not be shown at all for some situations so at run time when the
plugin launches I want to decide whether it should be shown or not. Can I
add a preference page programatically instead of using the plugin.xml
mechanism?
Re: How do I add a preferences page programatically at run time? [message #330518 is a reply to message #330517] Wed, 30 July 2008 19:24 Go to previous messageGo to next message
To replace this plugin.xml entry:
<extension
point = "org.eclipse.ui.preferencePages">
<page id="CounterPath.Preferences.Accounts.AccountsPage"
class="CounterPath.Preferences.Accounts.AccountsPage"
name="Telephony Accounts">
</page>
</extension>
I tried the following code:
org.eclipse.jface.preference.PreferenceNode node =
new org.eclipse.jface.preference.PreferenceNode(
"CounterPath.Preferences.Accounts.AccountsPage", "Telephony Accounts",
null, "CounterPath.Preferences.Accounts.AccountsPage");
org.eclipse.jface.preference.PreferenceManager mgr =
org.eclipse.ui.PlatformUI.getWorkbench().getPreferenceManage r();
mgr.addToRoot(node);
Which results in an entry for the page being created but when I click on
it I get the following:
SEVERE: Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
org.eclipse.jface.preference.PreferenceNode.createPage(Prefe renceNode.java:161)
org.eclipse.jface.preference.PreferenceDialog.createPage(Pre ferenceDialog.java:1241)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.cre atePage(FilteredPreferenceDialog.java:315)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1134)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:438)
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:661)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:839)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:837)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1578)
org.eclipse.jface.preference.PreferenceDialog.selectSavedIte m(PreferenceDialog.java:958)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sel ectSavedItem(FilteredPreferenceDialog.java:481)
org.eclipse.jface.preference.PreferenceDialog$3.run(Preferen ceDialog.java:345)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.preference.PreferenceDialog.createContents (PreferenceDialog.java:341)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1111)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.cr eateDialogOn(WorkbenchPreferenceDialog.java:96)
org.eclipse.ui.dialogs.PreferencesUtil.createPreferenceDialo gOn(PreferencesUtil.java:85)
CounterPath.Preferences.Accounts.AccountsPage.Show(AccountsP age.java:91)
CounterPath.SidePanel.Toolbar.ActionsButtonAction$2.widgetSe lected(ActionsButtonAction.java:102)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1932)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1896)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:424)
com.ibm.rcp.personality.framework.internal.RCPApplication.ru n(RCPApplication.java:72)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: How do I add a preferences page programatically at run time? [message #330519 is a reply to message #330518] Wed, 30 July 2008 21:21 Go to previous messageGo to next message
Originally posted by: lifesting.gmail.com
> <extension
> </page>
> </extension>
> org.eclipse.jface.preference.PreferenceNode node = new
> Accounts", null, "CounterPath.Preferences.Accounts.AccountsPage");
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
You'd better use IExtensionRegistry to add contributions dynamically at
runtime, e.g:
IExtensionRegistryTracker tracker = .....
IExtensionRegistry reg = tracer.getService(IExtensionRegistry.class...)
reg.addContribution(xxx,xxx)
Re: How do I add a preferences page programatically at run time? [message #330523 is a reply to message #330517] Thu, 31 July 2008 01:47 Go to previous messageGo to next message
> the plugin.xml file as in all the examples. Unfortunately this
> preference page should not be shown at all for some situations
I question whether that is really the right UI choice.
Will your users understand why the preferences are available sometimes
and not others?
Re: How do I add a preferences page programatically at run time? [message #330531 is a reply to message #330518] Thu, 31 July 2008 10:40 Go to previous messageGo to next message
> <extension
> </page>
> </extension>
Is CounterPath.Preferences.Accounts.AccountsPage really the FQCN? Put a
breakpoint in PreferenceDialog.createPage(*) and step through the
PreferenceNode code when creating your page. I suspect that jface
Class.forName(*) can't find the class. You might have to override
PreferenceNode.createPage(*) if supplying your own node.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How do I add a preferences page programatically at run time? [message #330539 is a reply to message #330518] Thu, 31 July 2008 15:25 Go to previous messageGo to next message
I also tried the following:
org.eclipse.core.runtime.IExtensionRegistry registry =
org.eclipse.core.runtime.Platform.getExtensionRegistry();
org.eclipse.core.runtime.IExtensionPoint point =
registry.getExtensionPoint("org.eclipse.ui.preferencePages");
boolean success = false;
if (point != null)
InputStream is = new StringBufferInputStream(
" <plugin><extension" +
" point = 'org.eclipse.ui.preferencePages'>" +
" <page id='CounterPath.Preferences.Accounts.AccountsPage'" +
" class='CounterPath.Preferences.Accounts.AccountsPage'" +
" name='Telephony Accounts'>" +
" </page>" +
" </extension></plugin>");
success = registry.addContribution(is, point.getContributor(), false,
"Telephony Accounts", null, null);
Which executed fine but when I try to show the preferences page I get an
error saying "Plugin org.eclipse.ui was unable to load class
CounterPath.Preferences.Accounts.AccountsPage." This class is there and
this works fine when I put the XML in the plugin.xml file. Do I need to
somehow register the class so it is found?
Re: How do I add a preferences page programatically at run time? [message #330540 is a reply to message #330531] Thu, 31 July 2008 15:27 Go to previous messageGo to next message
I believe it is the FQCN as the class is declared as such in the code and
when I load it using this same string via plugin.xml it works fine.
I am not able to step through this code you mentioned. Where do I get the
sources for this?
Re: How do I add a preferences page programatically at run time? [message #330541 is a reply to message #330523] Thu, 31 July 2008 15:28 Go to previous messageGo to next message
Yes, because if they don't see it they never will and if they do see it
they always will. The decision is constant for a given user.
Re: How do I add a preferences page programatically at run time? [message #330543 is a reply to message #330541] Thu, 31 July 2008 17:42 Go to previous messageGo to next message
Maybe it would be easier to define the preference page as usual and use
activities to enable/disable its availability to users.
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench_advext_activities.htm
Re: How do I add a preferences page programatically at run time? [message #330546 is a reply to message #330541] Fri, 01 August 2008 00:20 Go to previous messageGo to next message
Hm. Well, you certainly know your application and userbase better than
I do, but I will point out that the Eclipse newsgroups are full of posts
by people confused because they see something different than what
someone else sees.
Re: How do I add a preferences page programatically at run time? [message #330563 is a reply to message #330543] Fri, 01 August 2008 16:23 Go to previous messageGo to next message
Thanks for the pointer, this gets me most of the way there! The only
problem I have is when I disable the preference page I get two copies of
the buttons on my toolbar. Seems like the toolbar is being parsed a second
time when I disable the page. Weird since the toolbar is in a different
plugin. Even more weird is that if I repeatedly enable/disable the page I
still only get two copies of my toolbar buttons.
Here is my preference page XML:
<!-- Preferences "Telephony Accounts" page -->
<extension
</page>
</extension>
<!-- An activity to allow us to show/hide the "Telephony Accounts" page
<extension
point="org.eclipse.ui.activities">
<activity
description="Telephony Accounts Preferences"
id="CounterPath.Preferences.AccountsPageActivity">
</activity>
<activityPatternBinding
activityId="CounterPath.Preferences.AccountsPageActivity"
pattern="PALS/CounterPath\.Preferences\.Accounts\.AccountsPage ">
</activityPatternBinding>
<!-- <defaultEnablement id="CounterPath.Preferences.AccountsPageActivity"
</extension>
And the toolabr XML in the other plugin:
<!-- Notes toolbar -->
<extension
point="com.ibm.rcp.ui.controlSets">
<controlSet
align="left"
id="CounterPath.NotesToolbar.ToolbarContribution.set"
label="SMC Plug-in Toolbar"
visible="true">
<toolBar
id="CounterPath.NotesToolbar.ToolbarContribution.bar"
path="BEGIN_GROUP"/>
<control
class="CounterPath.NotesToolbar.ToolbarContribution"
id="CounterPath.NotesToolbar.ToolbarContribution"
toolbarPath="CounterPath.NotesToolbar.ToolbarContribution.bar "/>
</controlSet>
</extension>
And my code to disable the preference page:
org.eclipse.ui.activities.IWorkbenchActivitySupport
workbenchActivitySupport =
org.eclipse.ui.PlatformUI.getWorkbench().getActivitySupport( );
org.eclipse.ui.activities.IActivityManager activityManager =
workbenchActivitySupport.getActivityManager();
HashSet enabledIds = new HashSet(activityManager.getEnabledActivityIds());
if (enabledIds.remove("CounterPath.Preferences.AccountsPageActivity "))
workbenchActivitySupport.setEnabledActivityIds(enabledIds);
Re: How do I add a preferences page programatically at run time? [message #330588 is a reply to message #330563] Mon, 04 August 2008 11:47 Go to previous messageGo to next message
We do much the same thing, and have not seen this problem. It sounds
like a bug. Where is the code that disables the page running? We run it
in our override of ActionBarAdvisor.makeActions() and it works fine.
> second time when I disable the page. Weird since the toolbar is in a
> different plugin. Even more weird is that if I repeatedly enable/disable
> the page I still only get two copies of my toolbar buttons.
> <extension
> </page>
> </extension>
> page -->
> <extension
> <activity
> </activity>
> id="CounterPath.Preferences.AccountsPageActivity" /> -->
> </extension>
> <extension
> <controlSet
> align="left"
> visible="true">
> <toolBar
> <control
> </controlSet>
> </extension>
Re: How do I add a preferences page programatically at run time? [message #330829 is a reply to message #330540] Thu, 14 August 2008 08:56 Go to previous messageGo to next message
> and when I load it using this same string via plugin.xml it works fine.
Right, but the plugin.xml uses the OSGi classloaders ... the JFace
classloader won't be able to find your class. You might have to
override org.eclipse.jface.preference.PreferenceNode.createPage()
> the sources for this?
My target is an SDK target, and so it has the source included. You can
always use the update manager to download the source features from the
Europa (3.3) or Ganymede (3.4) discovery sites.
Later,
PW
Paul Webster
Re: How do I add a preferences page programatically at run time? [message #330831 is a reply to message #330539] Thu, 14 August 2008 08:57 Go to previous message
> if (point != null)
> " point = 'org.eclipse.ui.preferencePages'>" + " <page
> " </page>" +
> false, "Telephony Accounts", null, null);
Your contributor has to identify your plugin ... point.getContributor()
returns "org.eclipse.ui" which cannot load your class, you need to
create a contributor that returns your plugin.id.
PW
Paul Webster
Previous Topic:sorting table
Next Topic:Defining help contexts
Current Time: Wed Oct 29 15:29:29 EDT 2025
Powered by FUDForum. Page generated in 0.05659 seconds
