Home » Eclipse Projects » Eclipse Platform » correct way to open editors of various "types" (i.e., to create an EditorInput?)
| correct way to open editors of various "types" (i.e., to create an EditorInput?) [message #330471] |
Tue, 29 July 2008 14:32  |
R3.3, WinXP
We have currently two sorts of editors (call them "C" and "G") that
correspond to two Windoze-sorts of files; in the future, there will be
other sorts of editors/files. Each sort of editor is to be plugged in
(we use both the "org.eclipse.ui.editors" and the
"org.eclipse.ui.elementFactories" extension-points), and in a given
install any or all of these pluggable editors may be present or absent.
The editors are not all text-editors, but (so far) all use the
IPathEditorInput (or a subclass); the editors themselves could be of any
type, but I think that doesn't matter.
All these sorts of files are displayed in a kind of "Explorer" (not my
code), and it is desired to open the correct editor, when the user
double-clicks (or takes other actions, maybe activating a menu-item).
I've looked through items on these two newsgroups, and poked at the help
docs, and other web-pages (the
http://wiki.eclipse.org/index.php/JFaceSnippets is not really relevant,
of course, whereas the http://www.eclipse.org/articles/ which could be,
do not seem to have anything on this topic).
(A) ================================
Here is what I think is the correct Eclipse code to open an editor,
given the IEditorInput (wrapped in a try/catch (PartInitException) block):
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage()
IPath path = thisWeKnowHowToGet();
IPathEditorInput input = getInputSomehowOrOther(path);
String editorID = getIdSomehowOrOther(path);
page.openEditor(input, editorID, true);
So, first, am I right about that?
(B) ================================
In order to allow the various sorts of editors to be pluggable, clearly
the open-file action has to have some way of mapping from the file-name
to the editor-input *and* to the editor-id.
For the editor-id, this snippet does work, and I have used it before,
but am not sure it is the best practice:
IEditorRegistry reg = PlatformUI.getWorkbench().getEditorRegistry();
IEditorDescriptor descr = reg.getDefaultEditor(path.toOSString());
String editorID = descr.getId();
Is that the right way?
(C) ================================
I did find one way to map the *editorInputFactoryID* to the correct
editor-input class, and it works, but (a) I'd still like a
plug-in-correct way of getting that id, and (b) anyway, my
kluge-detector buzzes, for various reasons: (i) the
IDocumentEditorInput.TAG_PATH is a shared value in our system, which is
what we plan to use in all of our implementations of IPathEditrInput,
but ... requiring that is fragile, and (ii) since I have to create a
Memento on the fly.
(The "Document" stuff is just DOM4J, being used to create an XML string.)
IPathEditorInput getPathEditorInput(final IPath path, final String
factoryId) throws WorkbenchException {
IElementFactory factory =
PlatformUI.getWorkbench().getElementFactory(factoryId);
if (null == factory) {
throw new WorkbenchException("msg1");
Document doc = DocumentHelper.createDocument();
doc.addElement("root"); //$NON-NLS-1$ // any tag will do
String xml = doc.asXML();
IMemento memento =
XMLMemento.createReadRoot(new StringReader(xml));
memento.putString(
IDocumentEditorInput.TAG_PATH, path.toOSString());
IAdaptable adaptable = factory.createElement(memento);
if (adaptable instanceof IPathEditorInput) {
return (IPathEditorInput) adaptable;
throw new WorkbenchException("msg2");
So -- how do I *correctly* get the appropriate instance of an
IEditorInput simply from the {editorID, file-path} using Eclipse methods?
thanks,
Paul
PS -- we do have what I believe to be a correct equals() method in our
PathEditorInput subclasses.
| Re: correct way to open editors of various "types" (i.e., to create an EditorInput?) [message #330528 is a reply to message #330471] |
Thu, 31 July 2008 10:22   |
Paul Th. Keyser wrote:
> R3.3, WinXP
Yes, with all of the magic happening in your
getIdSomehowOrOther(IEditorInput). For IFileEditorInputs, check out
some of the methods that start on org.eclipse.ui.ide.IDE They get
editor descriptors for IFiles and can open editors (which they must turn
into IFileEditorInputs), although I see a method that can open a URI.
This looks fine, although be default I'm not sure if it works with files
outside the workspace.
The lookup for matching an IFile to an editor.id is first, the extension
matching, and then the IContentType scanning to narrow it down further.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
| Re: correct way to open editors of various "types" (i.e., to create an EditorInput?) [message #330544 is a reply to message #330528] |
Thu, 31 July 2008 19:08   |
Thanks for the answers to (A) and (B) ...
>> block):
Right, I did wind up going through those (maybe I missed something), and
see below ...
>> clearly the open-file action has to have some way of mapping from the
>> file-name to the editor-input *and* to the editor-id.
I think it does not work outside the WS, since IPath seems to be
WS-scope, as it were.
.... but what about (C)?
In the interval, I did (as mentioned above) go through the IDE calls
(well, some of them), and it seemed to me that what was happening was
that *all* files (whether my "C" or "G" or whatever) were being opened
using the *internal* Eclipse class FileEditorInput.
So my current solution is to have copied that (and its transitive
closure of interface and factory) and now we use the same "kluge" --
every file-type is opened using a com.mun.ist.FileEditorInput -- but I
still sort of think that having a specific factory registered for each
file-type might be better (maybe some files need some extra work, e.g.),
and that would then require some "registry" that mapped file-types to
factories ...
Does that exist?
thanks,
-Paul
| Re: correct way to open editors of various "types" (i.e., to create an EditorInput?) [message #330545 is a reply to message #330544] |
Thu, 31 July 2008 22:47  |
>>> block):
>> turn into IFileEditorInputs), although I see a method that can open a
>> URI.
> and see below ...
>>> the file-name to the editor-input *and* to the editor-id.
>>> before, but am not sure it is the best practice:
>> files outside the workspace.
> e.g.), and that would then require some "registry" that mapped
> file-types to factories ...
> Does that exist?
> thanks,
> -Paul
not that you should play with any of it, but for the curious:
org.eclipse.ui.internal.EditorManager {
public IEditorReference openEditor(String editorId, IEditorInput input,
boolean setVisible, IMemento editorState) throws
PartInitException {
if (editorId == null || input == null) {
throw new IllegalArgumentException();
IEditorRegistry reg = getEditorRegistry();
EditorDescriptor desc = (EditorDescriptor) reg.findEditor(editorId);
if (desc == null) {
throw new PartInitException(NLS.bind(
WorkbenchMessages.EditorManager_unknownEditorIDMessage,
editorId));
IEditorReference result = openEditorFromDescriptor(desc, input,
editorState);
return result;
org.eclipse.ui.internal.registry.EditorRegistry implements IEditorRegistry {
---> among maaaany other things:
private Map contentTypeToEditorMappings = new HashMap();
populated by the file ext/editor preference page.
cheers,
Laurent Mihalkovic, co-author SWT/JFace in Action (www.manning.com/scarpino)
Current Time: Thu Nov 13 11:08:39 EST 2025
Powered by FUDForum. Page generated in 0.04415 seconds
