Home » Eclipse Projects » Eclipse Platform » JFace snippet doesn't compile
JFace snippet doesn't compile [message #330391] Mon, 28 July 2008 06:00 Go to next message
Even though I'm using Eclipse 3.4, the following snippet doesn't compile:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
This is the error I get:
FocusBorderCellHighlighter cannot be resolved to a type
line 148
I've search unluckily for this class in the documentation and the Eclipse
source code.
Re: JFace snippet doesn't compile [message #330395 is a reply to message #330391] Mon, 28 July 2008 06:07 Go to previous messageGo to next message
By replacing FocusBorderCellHighlighter with
FocusCellOwnerDrawHighlighter, I can get it to compile. :-)
David Perez wrote:
> line 148
> source code.
Re: JFace snippet doesn't compile [message #330414 is a reply to message #330391] Mon, 28 July 2008 08:36 Go to previous messageGo to next message
David Perez wrote:
> line 148
> Eclipse source code.
It's possible that this snippet has already been updated to use the code
from the 3.5 development stream, and that FocusBorderCellHighlighter is
a new class in 3.5.
If you checked out the snippets project from CVS, I'd recommend to
replace the project with a tag that marked the release of 3.4
Hope this helps,
Eric
Re: JFace snippet doesn't compile [message #330419 is a reply to message #330414] Mon, 28 July 2008 08:47 Go to previous messageGo to next message
Hi Eric,
I haven't taken directly from CVS, but from the wiki:
http://wiki.eclipse.org/index.php/JFaceSnippets#Snippet021Ce llEditorsOnDoubleClick
> a new class in 3.5.
Re: JFace snippet doesn't compile [message #330581 is a reply to message #330414] Mon, 04 August 2008 08:26 Go to previous message
No the class he wants is also part of the snippet package! It's much
better to checkout the code directly from CVS!
Tom
Eric Rizzo schrieb:
> David Perez wrote:
>> line 148
> a new class in 3.5.
> Hope this helps,
> Eric
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Why ColumnViewerEditorActivationListener isn't called
Next Topic:Links in quick fix hovers
Current Time: Mon Jul 21 20:56:19 EDT 2025
Powered by FUDForum. Page generated in 0.26327 seconds
