Re: JFace snippet doesn't compile [message #330581 is a reply to message #330414] |
Mon, 04 August 2008 08:26  |
No the class he wants is also part of the snippet package! It's much
better to checkout the code directly from CVS!
Tom
Eric Rizzo schrieb:
> David Perez wrote:
>> Even though I'm using Eclipse 3.4, the following snippet doesn't compile:
>> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
>> This is the error I get:
>> FocusBorderCellHighlighter cannot be resolved to a type
>> line 148
>> I've search unluckily for this class in the documentation and the
>> Eclipse source code.
> It's possible that this snippet has already been updated to use the code
> from the 3.5 development stream, and that FocusBorderCellHighlighter is
> a new class in 3.5.
> If you checked out the snippets project from CVS, I'd recommend to
> replace the project with a tag that marked the release of 3.4
> Hope this helps,
> Eric
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
FUDForum. Page generated in 0.03598 seconds
