Home » Eclipse Projects » Eclipse Platform » Why ColumnViewerEditorActivationListener isn't called
Why ColumnViewerEditorActivationListener isn't called [message #330321] Fri, 25 July 2008 06:26 Go to next message
I have created a TableViewer and register a listener, which isn't called
at all, even when I double click a cell in order to edit it.
tableViewer.getColumnViewerEditor().addEditorActivationListe ner(new
ColumnViewerEditorActivationListener() {
@Override public void
afterEditorActivated(ColumnViewerEditorActivationEvent event) {
afterEditorDeactivated(ColumnViewerEditorDeactivationEvent event) {
beforeEditorActivated(ColumnViewerEditorActivationEvent event) {
CrudContentProvider.this.beforeEditorActivated(event);
beforeEditorDeactivated(ColumnViewerEditorDeactivationEvent event) {
Re: Why ColumnViewerEditorActivationListener isn't called [message #330322 is a reply to message #330321] Fri, 25 July 2008 06:38 Go to previous messageGo to next message
I'm going to explain more in depth my problem.
In my TableViewer, when the user changes the current row, its contents are
validated, and saved. If they aren't correct, the selection is set back
to the edited row.
I do this thru a selection listener:
viewer.addSelectionChangedListener(selChanged = new
ISelectionChangedListener() {
public void selectionChanged(final SelectionChangedEvent event) {
selectionChanged();
int lastIndex;
Object lastSel;
protected void selectionChanged() {
if (ignoreSel > 0) {
return;
ignoreSel++;
try {
IStructuredSelection sel =
(IStructuredSelection)viewer.getSelection();
Object sel1 = sel.getFirstElement();
if (sel1 == lastSel || saveCurrentRow()) {
lastSel = sel1;
lastIndex = viewer.getTable().getSelectionIndex();
} else {
viewer.cancelEditing();
// If we cannot save current row, then come back
viewer.getTable().setSelection(lastIndex);
} finally {
ignoreSel--;
The problem:
One the user double clicks a cell in another row, that cell is activated,
even though I set the selection back to the old row.
How can I stop the activation going to that cell?
Any help will be grealty appreciated.
Re: Is this the best place to JFace questions [message #330333 is a reply to message #330322] Fri, 25 July 2008 11:40 Go to previous messageGo to next message
I wonder if this is the right forum for JFace questions.
Re: Is this the best place to JFace questions [message #330339 is a reply to message #330333] Fri, 25 July 2008 14:21 Go to previous messageGo to next message
Yes, it is.
Re: Why ColumnViewerEditorActivationListener isn't called [message #330357 is a reply to message #330321] Fri, 25 July 2008 23:06 Go to previous messageGo to next message
Have you created TableViewerColumn objects and called setEditingSupport on
them?
"David Perez" <craquerpro@yahoo.es> wrote in message
news:97d3a0a17f893b9a8b7abf57dc88b011$1@www.eclipse.org...
>I have created a TableViewer and register a listener, which isn't called at
Re: Why ColumnViewerEditorActivationListener isn't called [message #330385 is a reply to message #330357] Mon, 28 July 2008 05:06 Go to previous messageGo to next message
Thanks Boris.
Yes, I've done so. Otherwise, editing a cell wouldn't work at all.
> them?
Re: Why ColumnViewerEditorActivationListener isn't called [message #330389 is a reply to message #330322] Mon, 28 July 2008 05:41 Go to previous messageGo to next message
If necessary, I can provide a full example.
> to the edited row.
> selectionChanged();
> int lastIndex;
> Object lastSel;
> return;
> ignoreSel++;
> try {
> lastSel = sel1;
> } else {
> } finally {
> ignoreSel--;
> The problem:
Re: Why ColumnViewerEditorActivationListener isn't called [message #330580 is a reply to message #330385] Mon, 04 August 2008 08:23 Go to previous message
Please provide a fully running snippet and then file a bug. CC me and
Boris and we'll have a look.
Tom
David Perez schrieb:
> Thanks Boris.
>> setEditingSupport on them?
>>> called at all, even when I double click a cell in order to edit it.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Default behaviour for find TableItem associated to a TableViewer element
Next Topic:JFace snippet doesn't compile
Current Time: Sat Nov 08 08:20:32 EST 2025
Powered by FUDForum. Page generated in 0.05402 seconds
