| Why ColumnViewerEditorActivationListener isn't called [message #330321] |
Fri, 25 July 2008 06:26  |
I have created a TableViewer and register a listener, which isn't called
at all, even when I double click a cell in order to edit it.
tableViewer.getColumnViewerEditor().addEditorActivationListe ner(new
ColumnViewerEditorActivationListener() {
@Override public void
afterEditorActivated(ColumnViewerEditorActivationEvent event) {
afterEditorDeactivated(ColumnViewerEditorDeactivationEvent event) {
beforeEditorActivated(ColumnViewerEditorActivationEvent event) {
CrudContentProvider.this.beforeEditorActivated(event);
beforeEditorDeactivated(ColumnViewerEditorDeactivationEvent event) {
| Re: Why ColumnViewerEditorActivationListener isn't called [message #330322 is a reply to message #330321] |
Fri, 25 July 2008 06:38   |
I'm going to explain more in depth my problem.
In my TableViewer, when the user changes the current row, its contents are
validated, and saved. If they aren't correct, the selection is set back
to the edited row.
I do this thru a selection listener:
viewer.addSelectionChangedListener(selChanged = new
ISelectionChangedListener() {
public void selectionChanged(final SelectionChangedEvent event) {
selectionChanged();
int lastIndex;
Object lastSel;
protected void selectionChanged() {
if (ignoreSel > 0) {
return;
ignoreSel++;
try {
IStructuredSelection sel =
(IStructuredSelection)viewer.getSelection();
Object sel1 = sel.getFirstElement();
if (sel1 == lastSel || saveCurrentRow()) {
lastSel = sel1;
lastIndex = viewer.getTable().getSelectionIndex();
} else {
viewer.cancelEditing();
// If we cannot save current row, then come back
viewer.getTable().setSelection(lastIndex);
} finally {
ignoreSel--;
The problem:
One the user double clicks a cell in another row, that cell is activated,
even though I set the selection back to the old row.
How can I stop the activation going to that cell?
Any help will be grealty appreciated.
| Re: Why ColumnViewerEditorActivationListener isn't called [message #330580 is a reply to message #330385] |
Mon, 04 August 2008 08:23  |
Please provide a fully running snippet and then file a bug. CC me and
Boris and we'll have a look.
Tom
David Perez schrieb:
> Thanks Boris.
> Yes, I've done so. Otherwise, editing a cell wouldn't work at all.
> Boris Bokowski wrote:
>> Have you created TableViewerColumn objects and called
>> setEditingSupport on them?
>> "David Perez" <craquerpro@yahoo.es> wrote in message
>> news:97d3a0a17f893b9a8b7abf57dc88b011$1@www.eclipse.org...
>>> called at all, even when I double click a cell in order to edit it.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
FUDForum. Page generated in 0.77564 seconds
