Home » Eclipse Projects » Eclipse Platform » Re: Cut/copy/paste at the widget level
Re: Cut/copy/paste at the widget level [message #330290] Thu, 24 July 2008 10:20 Go to next message
David Huebel wrote:
> What is the best way to declare custom cut/copy/paste behavior for a
> widget instance? If I were doing this at the view level I would
> use retargetable actions, but I need to do this for a single widget in
> a view. All the other widgets in the view should retain their usual
> cut/copy/paste behavior. Right now the widget is an instance of Composite,
> but I could subclass Composite if necessary.
Within eclipse you can use the IFocusService to register a specific
control to the system (using an id, usually).
Then you can activate a handler for that Control using the appropriate
activeWhen clause (and org.eclipse.ui.handlers) or by using a Expression
and IHandlerService#activateHandler(*).
See ISources and http://wiki.eclipse.org/Command_Core_Expressions for a
discussion of variables available, and IFocusService javadoc for a
description of its use.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Cut/copy/paste at the widget level [message #330507 is a reply to message #330290] Wed, 30 July 2008 12:09 Go to previous message
> PW
Thanks! This is exactly what I needed.
-David
Previous Topic:Ctrl+S different behaviour in Eclipse 3.3 and 3.4
Next Topic:Annotation Hilighting
Current Time: Sun Oct 19 19:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.06253 seconds
