Home » Eclipse Projects » Eclipse Platform » Couldn't uninstall a plugin using P2
| Couldn't uninstall a plugin using P2 [message #330281] |
Thu, 24 July 2008 09:12 |
Originally posted by: mauro.molinari.cardinis.com
Hello all!
After installing TPTP Platform Integration PDE to make a test, I can't
uninstall it anymore. When I select it and hit "Uninstall", the process
of resolving the dependeces produces the following output in the log.
Then, when I click Finish, nothing happens (I would expect the plugin is
uninstalled, but this doesn't occur).
The content of the log is the following:
!ENTRY org.eclipse.equinox.p2.director 2 0 2008-07-24 15:08:09.171
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-07-24 15:08:09.171
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui
1.0.305.v200802142230 to requiredCapability:
osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common.ui
1.0.1.v20070912 to requiredCapability:
osgi.bundle/org.eclipse.emf/[2.2.0,2.4.0).
1.0.2.v200802201120 to requiredCapability:
osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core
osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui
1.1.200.v200705302225 to requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.search/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.jface.text/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 ).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee
1.1.107.v200803071930 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
1.1.106.v200802192030 to requiredCapability:
1.1.107.v200806252211 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web
1.1.105.v200802192030 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core
1.1.203.v200802140626 to requiredCapability:
org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to
requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.mylyn.ide.ui
3.0.1.v20080721-2100-e33 to requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core
1.1.101.v200706120315 to requiredCapability:
osgi.bundle/org.eclipse.core.expressions/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emf
1.1.104.v200709131115 to requiredCapability:
org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.core
1.1.104.v200802192030 to requiredCapability:
org.eclipse.jst.common.frameworks 1.1.102.v200709122200 to
org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to
!MESSAGE Unable to satisfy dependency from org.eclipse.jem
2.0.100.v200709051030 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.3.0,2.4.0).
org.eclipse.wst.common.frameworks 1.1.103.v200802192030 to
org.eclipse.jst.common.annotations.controller 1.1.2.v200708301745 to
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web
1.1.103.v200802192030 to requiredCapability:
org.eclipse.wst.common.environment 1.0.200.v200705302225 to
requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee
1.0.3.v200803242054 to requiredCapability:
1.0.3.v200806261300 to requiredCapability:
1.0.2.v200802192030 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.dtd.core
1.1.101.v200705302225 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.xsd.core
1.1.202.v200710011705 to requiredCapability:
osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env
1.0.205.v200710161954 to requiredCapability:
osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.ws
1.0.205.v200801222138 to requiredCapability:
org.eclipse.wst.command.env.ui 1.0.203.v200709052219 to
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.ws.ui
1.0.202.v200708202218 to requiredCapability:
org.eclipse.jst.ws.consumption 1.0.205.v200711222108 to
requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
org.eclipse.jst.ws.consumption.ui 1.0.206.v200712220541 to
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws
1.0.204.v200711140435 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl
1.1.101.v200801152132 to requiredCapability:
org.eclipse.jst.common.annotations.core 1.1.2.v200706120315 to
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.jca
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.ejb
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.explorer
1.0.206.v200802072125 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui
1.0.203.v200708222126 to requiredCapability:
org.eclipse.jst.j2ee.webservice 1.1.102.v200802192030 to
org.eclipse.jst.j2ee.webservice.ui 1.1.103.v200802192030 to
requiredCapability: osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
org.eclipse.jst.server.generic.core 1.0.205.v200709061325 to
org.eclipse.jst.server.tomcat.core 1.1.2.v20071023 to
org.eclipse.jst.j2ee.ejb.annotation.model 1.1.2.v200706120315 to
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web.ui
1.1.101.v200706071630 to requiredCapability:
org.eclipse.jst.ws.axis.consumption.core 1.0.204.v200708151945 to
org.eclipse.jst.ws.axis.consumption.ui 1.0.204.v200801222138 to
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.ui
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.ejb.ui
1.1.102.v200709122200 to requiredCapability:
org.eclipse.jst.j2ee.navigator.ui 1.1.102.v200709122200 to
org.eclipse.jst.j2ee.ejb.annotations.emitter 1.1.2.v200708301745 to
org.eclipse.jst.j2ee.ejb.annotations.xdoclet 1.1.3.v200802201934 to
requiredCapability: osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsi
1.0.105.v200706120315 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.servlet.ui
Any help would be appreciated.
Mauro.
Current Time: Thu Nov 13 00:47:07 EST 2025
Powered by FUDForum. Page generated in 0.04096 seconds
