Home » Eclipse Projects » Eclipse Platform » Genymede error while using emacs scheme
Genymede error while using emacs scheme [message #330276] Thu, 24 July 2008 07:05 Go to next message
may be not the right place for this post, but I did not find any better:
I use the emacs key scheme for Java development, and I am having problems
with shortcuts since I switched from Europe to Ganymede.
Couple examples:
- Shift+Ctrl+F should format the text, but an 'F' appears instead at the
cursor position, then disappears.
- Shift+Ctrl+C should comment/uncomment the selected text, but instead it
deletes the selected text.
If I play around in the Preferences/General/Keys, sometimes the problems
vanish.
So the test sequence should be: set the SDK to use the emacs scheme,
restart the application, and then try the shortcuts mentioned above in a
Java source editor.
My environment:
Eclipse SDK
Version: 3.4.0
Build id: I20080617-2000
OS:
CentOS 4.6
kernel: 2.6.9-55.0.6.EL
Hardware:
Dell Latitude D610
Marton
Re: Genymede error while using emacs scheme [message #330289 is a reply to message #330276] Thu, 24 July 2008 10:14 Go to previous messageGo to next message
Marton Sigmond wrote:
> problems with shortcuts since I switched from Europe to Ganymede.
> Couple examples:
This is usually seen on older version of eclipse/older version of GTK+.
It's a sign that GTK is using CTRL+SHIFT+0-9A-F for unicode entry (as
opposed to CTRL+SHIFT+U, the modern way).
What version of gtk2 are you running?
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Genymede error while using emacs scheme [message #330291 is a reply to message #330289] Thu, 24 July 2008 10:28 Go to previous message
The gtk+.i386 1:1.2.10-36 is the one I use.
Please note that I have never experienced this problem with Eclipse Europe.
This problem was introduced by Eclipse Ganymede.
Thanks and regards,
Marton
Previous Topic:Change configuration location dynamically? Best practice?
Next Topic:How to change junit launch configuration's default classpath?
Current Time: Tue Oct 21 18:01:08 EDT 2025
Powered by FUDForum. Page generated in 0.03154 seconds
