| Genymede error while using emacs scheme [message #330276] |
Thu, 24 July 2008 07:05   |
Eclipse User  |
may be not the right place for this post, but I did not find any better:
I use the emacs key scheme for Java development, and I am having problems
with shortcuts since I switched from Europe to Ganymede.
Couple examples:
- Shift+Ctrl+F should format the text, but an 'F' appears instead at the
cursor position, then disappears.
- Shift+Ctrl+C should comment/uncomment the selected text, but instead it
deletes the selected text.
If I play around in the Preferences/General/Keys, sometimes the problems
vanish.
So the test sequence should be: set the SDK to use the emacs scheme,
restart the application, and then try the shortcuts mentioned above in a
Java source editor.
My environment:
  Eclipse SDK
    Version: 3.4.0
    Build id: I20080617-2000
  OS:
    CentOS 4.6
    kernel: 2.6.9-55.0.6.EL
  Hardware:
    Dell Latitude D610
Marton
FUDForum. Page generated in 0.03534 seconds
