Home » Eclipse Projects » Eclipse Platform » Access to MessageDialog object
Access to MessageDialog object [message #330271] Thu, 24 July 2008 03:31 Go to next message
I want to write a test in JUnit to see that an Error Dialog pops up with
the correct message.
How, in my unit test, do I get at the MessageDialog object my that my
program creates?
I assume I need to do
PlatformUI.getWorkbench().getDisplay().getActiveShell() or
PlatformUI.getWorkbench().getDisplay().getActiveShell().getC hildren(), but
from there I'm lost...
Re: Access to MessageDialog object [message #330273 is a reply to message #330271] Thu, 24 July 2008 04:05 Go to previous message
I just subclass it and put a static that points to the current instance
for testing purposes. I don't think there is any other way you can find it.
> program creates?
> but from there I'm lost...
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:Modifying plugin.xml file programmatically
Next Topic:ImportOperation - import project files into custom project
Current Time: Sat Jul 26 12:37:29 EDT 2025
Powered by FUDForum. Page generated in 0.04466 seconds
