Home » Eclipse Projects » Eclipse Platform » Programmatically generating a launch configuration
Programmatically generating a launch configuration [message #330263] Wed, 23 July 2008 12:46 Go to next message
Hi all,
Firstly, apologies if this is posted to the wrong newsgroup. Please
redirect me if this is the case.
My problem is that I would like to generate a launch configuration
programmatically from a plug-in. How can I do this?
I presume it is something to do with the Launch Manager - i.e.
org.eclipse.debug.core.DebugPlugin.getDefault().getLaunchMan ager() - but
I'm not sure how to instantiate a new Launch Configuration. Any ideas?
Many thanks,
Louis Rose.
Re: Programmatically generating a launch configuration [message #330264 is a reply to message #330263] Wed, 23 July 2008 13:11 Go to previous messageGo to next message
Louis Rose wrote:
> Hi all,
> Many thanks,
> Louis Rose.
Did you take a look at
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
Launch configs are stored as files in your workspace .metadata under
org.eclipse.debug.core. From the LaunchManager you can get
LaunchConfigurationTypes allow you get a LaunchConfigurationWorkingCopy
with newInstance() then operate on it and call doSave() to write the
file into the .metadata store. Then you will see it in the UI and you
can launch on it.
John
Re: Programmatically generating a launch configuration [message #330393 is a reply to message #330264] Mon, 28 July 2008 06:01 Go to previous message
John J Barton wrote:
> Louis Rose wrote:
>> Hi all,
>> but I'm not sure how to instantiate a new Launch Configuration. Any
>> ideas?
>> Many thanks,
>> Louis Rose.
> can launch on it.
> John
Hi John,
Many thanks; this is exactly what I was looking for.
Louis.
Previous Topic:Linked resouces in .project do no show
Next Topic:Disappearing marker problem
Current Time: Tue Jul 15 05:04:53 EDT 2025
Powered by FUDForum. Page generated in 0.07212 seconds
