Home » Eclipse Projects » Eclipse Platform » Checkbox in TableCells - Screenshots of Button fails
Checkbox in TableCells - Screenshots of Button fails [message #330237] Tue, 22 July 2008 11:52 Go to next message
Originally posted by: sf.tragwerk-software.de
I use screenshots of buttons as described in
http://tom-eclipse-dev.blogspot.com/2007/01/tableviewers-and -nativelooking.html
to get a table full of simulated Checkbox-Widgets.
Everything is working fine except when the screenshot is taken at a
point where the appplication has no active shell (e.g. bringing another
application in front during startup). Then the image is taken from the
active shell.
OS: Windows XP
Not sure wheter this is SWT related. Any hints ?
Sebastian
Re: Checkbox in TableCells - Screenshots of Button fails [message #330240 is a reply to message #330237] Tue, 22 July 2008 12:13 Go to previous messageGo to next message
I've experienced exactly the same problem.
Sebastian Fuchs wrote:
> active shell.
> OS: Windows XP
Re: Checkbox in TableCells - Screenshots of Button fails [message #330645 is a reply to message #330237] Thu, 07 August 2008 03:21 Go to previous messageGo to next message
just pinging for reactivation of this thread.
any suggestions ?
Sebastian
Sebastian Fuchs schrieb:
> active shell.
> OS: Windows XP
> Sebastian
Re: Checkbox in TableCells - Screenshots of Button fails [message #330646 is a reply to message #330645] Thu, 07 August 2008 03:24 Go to previous messageGo to next message
Maybe you should force the shell be get in to the foreground by creating
the shell with SWT.ON_TOP? This looks like an SWT problem maybe you
should create a snippet only holding the makeShot method and post it to
the SWT-newsgroup.
Tom
> any suggestions ?
> Sebastian
>> another application in front during startup). Then the image is taken
>> from the active shell.
>> OS: Windows XP
>> Thanks,
>> Sebastian
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Checkbox in TableCells - Screenshots of Button fails [message #330649 is a reply to message #330646] Thu, 07 August 2008 05:36 Go to previous message
Thanks Tom,
SWT.ON_TOP helped.
SWT newsgroup is already informed. Unfortunately there hasn't been any
response.
Sebastian
> the SWT-newsgroup.
> Tom
Previous Topic:Control visibility of an action declared in plugin.xml
Next Topic:inwanted shutdown.
Current Time: Sun Jul 27 07:15:52 EDT 2025
Powered by FUDForum. Page generated in 0.04203 seconds
