Home » Eclipse Projects » Eclipse Platform » Plugins with different versions, one as project, one as jar
Plugins with different versions, one as project, one as jar [message #330231] Tue, 22 July 2008 05:31 Go to next message
I've got two versions of the same library-plugin, one as a jar-file in
the plugin-directory and the newer one as project in the workspace. If
I configure a dependency on another plugin to the old version of my
lib-plugin, Eclipse gives an error "Unsatisfied version constraint". If
I close the the lib-plugin-project, the error goes away.
If I package both lib-plugin-versions as jars, it also works.
Could this be a bug or am I doing something wrong?
I tested this on 3.3 and 3.4.
This is the line that gives the error:
Require-Bundle: de.qs.framework;bundle-version="[1.2.0,1.2.1)"
while having a plugin-project with version 1.2.1 and a jar with version
1.2.0 in the plugin-dir.
Manuel
Re: Plugins with different versions, one as project, one as jar [message #330239 is a reply to message #330231] Tue, 22 July 2008 11:58 Go to previous messageGo to next message
Manuel Steurer wrote:
AFAIK PDE picks your workspace project over your target platform plugin
(that's standard). Your version constraint precludes 1.2.1 and PDE
won't make 1.2.0 visible (hence the error).
I would say the solution (as you found) is to close your workspace
project or change your version constraint to something like [1.2.0,1.2.1]
You can open an enhancement request against PDE as well.
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Plugins with different versions, one as project, one as jar [message #330252 is a reply to message #330239] Wed, 23 July 2008 02:52 Go to previous message
Thanks for your reply.
It's not really a solution to my problem,
since I want one project to depend on the old
version and not the new one. I have other projects
that do depend on the new version (under active
development), though.
It's no big deal and certainly no longtime situation
for me, it just struck me as odd.
> > Hi,
> > in the plugin-directory and the newer one as project in the
> > workspace. If I configure a dependency on another plugin to the old
> > version of my lib-plugin, Eclipse gives an error "Unsatisfied
> > version constraint". If I close the the lib-plugin-project, the
> > error goes away. If I package both lib-plugin-versions as jars, it
> > also works. Could this be a bug or am I doing something wrong?
> > version 1.2.0 in the plugin-dir.
> plugin (that's standard). Your version constraint precludes 1.2.1
> and PDE won't make 1.2.0 visible (hence the error).
> [1.2.0,1.2.1]
Previous Topic:CCombo and Databinding
Next Topic:Contributing ToggleState menu items or ViewFilter(Action) contributions.. (using eclipse 3.3)
Current Time: Wed Nov 05 04:47:18 EST 2025
Powered by FUDForum. Page generated in 0.03093 seconds
