Source -> Format context menu action [message #330204] |
Sun, 20 July 2008 12:34  |
I had already asked this question, but probably I didn't make myself
clear, so I'll try to explain this issue.
I created a source formatter for my plugin, attached to the source
viewer and I can execute it from a menu of my own; However, I'd like it
to be run from the Source -> Format context menu that it appears in the
project explorer when you right click on a file (that is not a Java
file), as shown in this picture
http://img111.imageshack.us/img111/5048/eclipseformatjy9.png
I assume this action is defined by some ActionFactory (not the standard
one however, since it does not define FORMAT), and that this action can
be retarget. The default implementation for files that are not standard
is a message box saying that this action is not enabled.
But who's defining this action?
Or how could I find this out?
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Source -> Format context menu action [message #330680 is a reply to message #330204] |
Fri, 08 August 2008 07:05  |
> it to be run from the Source -> Format context menu that it appears in
> the project explorer when you right click on a file (that is not a
> Java file), as shown in this picture
> standard one however, since it does not define FORMAT), and that this
> action can be retarget. The default implementation for files that are
> not standard is a message box saying that this action is not enabled.
You have to do this. Currently it is Java-specific.
Dani
> thanks in advance
> Lorenzo
FUDForum. Page generated in 0.03504 seconds
