Home » Eclipse Projects » Eclipse Platform » Open files always in external editor instead of in-place editor
Open files always in external editor instead of in-place editor [message #330202] Sun, 20 July 2008 10:14
I'm using the CNF & the IDE-Plugin in a RCP application to build an explorer
view. Everything works fine with the CNF, I just want to let files always open
with the external editor instead of the in-place editor (per default). Can I do
this without changing the IDE sources?
I tried:
PlatformUI.getWorkbench().getEditorRegistry().setDefaultEdit or( "*.pdf",
IEditorRegistry.SYSTEM_EXTERNAL_EDITOR_ID);
.... but with no success.
I looked into the IDE class and it's #getEditorDescriptor method. The sequence
for figuring out the proper editor seems:
1) Is there a specific editor for THIS file resource (marked per PersistentProperty)
2) Can we find an In-Place editor?
3) Can we find an External editor?
4) Opens the file in a text editor
I can't see a way to prefer the external editor (3) over the in-place editor (2).
PS: I'm using Eclipse 3.2 ... but in 3.3 it seems to be the same, cause when I
just copy a *.doc file into the resource navigator and double click on it, an
OLE editor opens (in-place).
Regards, Alex
Previous Topic:nested projects in eclipse?
Next Topic:Software Update not available
Current Time: Tue Jul 22 00:44:47 EDT 2025
Powered by FUDForum. Page generated in 0.03585 seconds
