Home » Eclipse Projects » Eclipse Platform » P2 and unresolved dependencies
P2 and unresolved dependencies [message #330194] Fri, 18 July 2008 12:13 Go to next message
Originally posted by: roy.paterson.smartbearsoftware.com
I'm having a problem with P2 and unresolved dependencies. I make a
product which is packaged as an Eclipse feature that my customers
install in to their existing Eclipse installs. My product integrates
with several 3rd-party team provider plugins, e.g. CVS (from Eclipse),
Subclipse, P4WSAD, Clearcase, etc...
Various bits of my code depend on code in those 3rd-party plugins.
Typically a customer will only have one team plugin installed, for the
SCM system they're using. To support this my feature includes "adapter"
plugins, one for each of those 3rd party plugins. My "adapter" plugins
each require one of the 3rd-party plugins. My core plugin provides an
extension point which my adapter plugins implement. In a typical
installation, only one of my 3rd party plugins would resolve, and my
core code would use that one.
This pattern worked fine in Eclipse 3.0 - 3.3, but seems to have
problems with Eclipse 3.4, specifically with P2. I am able to install
my feature with no errors and it works fine. However if I then try and
install anything else P2 gives me lots of "Unsatisfied dependency" errors:
Cannot complete the request. See the details.
Unsatisfied dependency: [com.smartbear.collaborator.ui.accurev
5.0.5001.1048] requiredCapability: osgi.bundle/com.accurev.eclipse/0.0.0
Unsatisfied dependency: [com.smartbear.collaborator.ui.perforce
5.0.5001.1048] requiredCapability: osgi.bundle/com.perforce.team.core/0.0.0
5.0.5001.1048] requiredCapability: osgi.bundle/com.perforce.p4api/0.0.0
5.0.5001.1048] requiredCapability: osgi.bundle/com.perforce.team.ui/0.0.0
[com.smartbear.collaborator.base.feature.feature.group 5.0.5001.1048]
requiredCapability:
org.eclipse.equinox.p2.iu/com.smartbear.collaborator.ui.accu rev/[5.0.5001.1048,5.0.5001.1048]
requiredCapability:
org.eclipse.equinox.p2.iu/com.smartbear.collaborator.ui.perf orce/[5.0.5001.1048,5.0.5001.1048]
P2 is correct in a sense - those 3rd-party plugins ARE required by my
plugins, and they can't resolve. But this is working as designed, and
was not a problem before P2.
So how should this work? Is there a different way I should be
implementing this 3rd-party-plugin integration pattern? At any rate it
seems like a bug for P2 to allow my plugin to install and work, but then
complain later when I try to install something unrelated.
Roy Paterson
Smart Bear Software
Re: P2 and unresolved dependencies [message #330223 is a reply to message #330194] Mon, 21 July 2008 12:56 Go to previous message
> requiredCapability:
> requiredCapability:
> Roy Paterson
> Smart Bear Software
I've re-routed to a group that's more in the "know"
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Adding a template to a custom extension point
Next Topic:Refresh workspace on switching perspective
Current Time: Sun Nov 09 02:39:34 EST 2025
Powered by FUDForum. Page generated in 0.03191 seconds
