Home » Eclipse Projects » Eclipse Platform » Eclipse test Framework and junit 4
Eclipse test Framework and junit 4 [message #330187] Fri, 18 July 2008 10:32 Go to next message
Originally posted by: fireresq.embarqmail.com
If this is the wrong news group to ask this please let me know the correct group.
I'm using the Eclipse test framework to run tests on my Eclipse plugins. I have users that have just recently converted to
Junit 4. Every time I run my build and try to run the test I get junit.framework.AssertionFiled: No tests found in
xxx.yyy.TestAll at .....
I have done searches on the web and can not find any documents stating how to use the Eclipse testing framework and Junit 4.
I'm using eclipse 3.4 to test this but will run tests on both Eclipse 3.3 and 3.2 on the build box.
Re: Eclipse test Framework and junit 4 [message #330216 is a reply to message #330187] Mon, 21 July 2008 11:19 Go to previous message
> plugins. I have users that have just recently converted to Junit 4.
> junit.framework.AssertionFiled: No tests found in xxx.yyy.TestAll at .....
You should add yourself to this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153429.
Olivier
Previous Topic:Software Updates Manager leaves my plug-in in ./plugins after deinstallation.
Next Topic:Debug: 'process model delta' has encountered a problem
Current Time: Sat Nov 22 08:03:06 EST 2025
Powered by FUDForum. Page generated in 0.03800 seconds
