Home » Eclipse Projects » Eclipse Platform » Different behaviour in CVS client from Eclipse 3.3 to Eclipse 3.4
Different behaviour in CVS client from Eclipse 3.3 to Eclipse 3.4 [message #330151] Thu, 17 July 2008 06:42 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello all!
In Eclipse 3.3 when a file is marked as modified (=> outgoing change),
but meanwhile someone else has committed a change in the repository, if
you right click on that file in the Synchronization Perspective and
choose "update", that file is updated (merging the changes) from the
repository.
In Eclipse 3.4 this does not happen. If you choose "update" Eclipse says
that there are no incoming changes for that file, even if this is not
true: in fact, if you try to commit, you'll receive an up-to-date-check
failed. You have to right click on that file and choose "Synchronize" in
order to see it marked as conflicting: only then you can right click =>
update to get the incoming changes marged with your local changes.
I'm using the CVS support in Eclipse.
Was this changed by design?
Thanks in advance,
Mauro.
Re: Different behaviour in CVS client from Eclipse 3.3 to Eclipse 3.4 [message #330160 is a reply to message #330151] Thu, 17 July 2008 11:32 Go to previous messageGo to next message
Mauro,
I doubt this was by design. You should log a bug report against
Platform/CVS.
Michael
Mauro Molinari wrote:
> Hello all!
> repository.
> Thanks in advance,
> Mauro.
Re: Different behaviour in CVS client from Eclipse 3.3 to Eclipse 3.4 [message #330174 is a reply to message #330160] Fri, 18 July 2008 03:12 Go to previous message
Michael Valenta ha scritto:
> Mauro,
> Platform/CVS.
> Michael
Thank you Michael, here it is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241350
Mauro.
Previous Topic:Very strange LinkageError during plugin loading
Next Topic:Can I set the line spacing for editor?
Current Time: Fri Oct 24 17:14:00 EDT 2025
Powered by FUDForum. Page generated in 0.04526 seconds
