Different behaviour in CVS client from Eclipse 3.3 to Eclipse 3.4 [message #330151] |
Thu, 17 July 2008 06:42  |
Originally posted by: mauro.molinari.cardinis.com
Hello all!
In Eclipse 3.3 when a file is marked as modified (=> outgoing change),
but meanwhile someone else has committed a change in the repository, if
you right click on that file in the Synchronization Perspective and
choose "update", that file is updated (merging the changes) from the
repository.
In Eclipse 3.4 this does not happen. If you choose "update" Eclipse says
that there are no incoming changes for that file, even if this is not
true: in fact, if you try to commit, you'll receive an up-to-date-check
failed. You have to right click on that file and choose "Synchronize" in
order to see it marked as conflicting: only then you can right click =>
update to get the incoming changes marged with your local changes.
I'm using the CVS support in Eclipse.
Was this changed by design?
Thanks in advance,
Mauro.
FUDForum. Page generated in 0.06030 seconds
