| Transitive plugin version dependencies [message #330146] |
Wed, 16 July 2008 18:49  |
We need to have plugins of two different version numbers in the same
Eclipse directory. The question is how transitive dependencies are handled
by Eclipse (or OSGI).
Example:
Plugin A1.0 uses 3rd party plugin B1.0. Plugin B1.0 uses Plugin C1.0.
In the dependencies it is specified that A1.0 needs B1.0 (exact versin
number). But B1.0 is third party, ant it depends on C1.0-C2.0 (version
range). This cannot be changed since B and C are third party plugins.
In the plugins folder there are these plugins A1.0, B1.0, B2.0, C1.0 and
C2.0.
Of course A1.0 will use B1.0, because it is specified so in the
dependencies. But will B1.0 use C1.0 or C2.0? In its dependencies there is
a range from 1.0 to 2.0. Which one will it use when both are available?
C2.0 must not be used. Maybe its not used anyway. I am asking you this.
But if it is used, could it be possible to restrict it to 1.0? Remember
that B and C are 3rd party plugins and that both plugin versions need to
be in the plugins folder because another plugin needs them.
A bit complicated, I know.
| Re: Transitive plugin version dependencies [message #330152 is a reply to message #330146] |
Thu, 17 July 2008 07:38  |
Hans,
I'll answer how I think it works. Someone ought to contradict me if I'm
wrong...
> handled by Eclipse (or OSGI).
> Example:
> and C2.0.
Some issues to consider. Many plugins are singletons and that mean two
versions of them cannot both be instantiated. I believe OSGi will always
want to prefer activating the one with the highest version number. But
of course it will also want to resolve version dependencies such that it
can activate the most plugins. I've heard that this general problem is
perhaps an NP-hard or even NP-complete problem to solve optimally.
> there is a range from 1.0 to 2.0. Which one will it use when both are
> available?
I think it will tend to prefer the higher numbered version unless other
constraints force a different choice. You could make A 1.0 itself
specify a version for C that might be more restrictive than B's range,
right?
> this. But if it is used, could it be possible to restrict it to 1.0?
I think A itself could do that.
> Remember that B and C are 3rd party plugins and that both plugin
> versions need to be in the plugins folder because another plugin needs
> them.
If B and C are singletons and other plugins specific require C 2.0 but
you want C 1.0 I think you'll find someone is a loser.
Theory and practice don't always coincide. Test, test, test....
FUDForum. Page generated in 0.03292 seconds
