Home » Eclipse Projects » Eclipse Platform » Links in quick fix hovers
Links in quick fix hovers [message #330144] Wed, 16 July 2008 18:13 Go to next message
Hy.
How are those links in the JavaDoc/quick fix hovers of JDT implemented?
The DefaultInformationControl just uses a StyledText as control. Are those
JavaDoc hover links only available in a special implementation of an
InformationControl in JDT? Or is this feature also available in jface.text?
(I want to use this for a RCP application using a TextViewer.)
Kai
Re: Links in quick fix hovers [message #330582 is a reply to message #330144] Mon, 04 August 2008 08:30 Go to previous message
Kai Schlamp wrote:
> Hy.
> implemented? The DefaultInformationControl just uses a StyledText as
> control. Are those JavaDoc hover links only available in a special
> implementation of an InformationControl in JDT? Or is this feature
The links are different in Javadoc and Problem hover: the Javadoc hover
is shown in a Browser widget and the links are HTML links. In the
Problem hover we use the SWT Link widget (see
org.eclipse.jdt.internal.ui.text.java.hover.AbstractAnnotati onHover.AnnotationInformationControl
for details).
Dani
> Best regards,
> Kai
Previous Topic:JFace snippet doesn't compile
Next Topic:Splashscreen and taskbar
Current Time: Fri Nov 07 05:49:15 EST 2025
Powered by FUDForum. Page generated in 0.03516 seconds
