Home » Eclipse Projects » Eclipse Platform » Modifying plugin.xml file programmatically
Modifying plugin.xml file programmatically [message #330137] Wed, 16 July 2008 10:25 Go to next message
Originally posted by: malloovidio.bluewin.ch
Hi all,
I have a project builder which, among other things, should modify
some parts of the plugin.xml file. More concretely, I want to automatically
add an additional enablement-condition to actions defined in the plugin.xml
file. Therefore, I wanted to ask whether there is some API to read in
specific extensions (the actions in the actionSet) and modify part of it
(the enablement)?
Thanks in advance for any help.
Ovidio
Re: Modifying plugin.xml file programmatically [message #330219 is a reply to message #330137] Mon, 21 July 2008 12:36 Go to previous messageGo to next message
Ovidio Mallo wrote:
> Hi all,
> (the enablement)?
Check out how the org.eclipse.pde.internal.ui.editor.PDEFormEditor does
it (complicated example, admittedly). Most changes seem to be made
using org.eclipse.pde.core.plugin.IPluginElement
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Modifying plugin.xml file programmatically [message #330226 is a reply to message #330137] Mon, 21 July 2008 15:14 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Ovidio Mallo wrote:
> Hi all,
> (the enablement)?
There's no public API to do this... here is a bug you may be interested in:
216037: [API] Way to modify MANIFEST files
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216037
~ Chris
Re: Modifying plugin.xml file programmatically [message #330272 is a reply to message #330226] Thu, 24 July 2008 03:48 Go to previous message
Paul & Chris,
thanks a lot for the pointers. I have ended up using the IPluginElement
interface to get it running. As Chris noted, it needs internal API to
be used but for now I can live with that.
Thanks again for the help!
Ovidio
Chris Aniszczyk wrote:
> Ovidio Mallo wrote:
>> Hi all,
>> automatically
>> plugin.xml
>> (the enablement)?
> Cheers,
> ~ Chris
Previous Topic:Question about Common Navigator and drop adapter assistants
Next Topic:Access to MessageDialog object
Current Time: Sat Nov 15 15:25:35 EST 2025
Powered by FUDForum. Page generated in 0.07318 seconds
