Home » Eclipse Projects » Eclipse Platform » Can I use JavaTypeCompletionProcessor in my project?
Can I use JavaTypeCompletionProcessor in my project? [message #330033] Sun, 13 July 2008 15:36 Go to next message
I am creating a wizard where the user must select a class. I did not
want to reinvent the wheel so I took a look at the "New Java
Class"-wizard where auto-completion is available in the
"Superclass"-textfield. Actually, I need exactly this field but I don't
know how to use the JavaTypeCompletionProcessor. Is there a way to
integrate get such a field into my own wizard?
Thank you so far
Lars Schneider
Re: Can I use JavaTypeCompletionProcessor in my project? [message #330055 is a reply to message #330033] Mon, 14 July 2008 05:38 Go to previous messageGo to next message
Lars Schneider wrote:
> don't know how to use the JavaTypeCompletionProcessor. Is there a way
> to integrate get such a field into my own wizard?
No, you have to copy the code if you only want the field. Another
approach might be to extend the existing New Java Class wizard with your
own page.
Dani
> Thank you so far
> Lars Schneider
Re: Can I use JavaTypeCompletionProcessor in my project? [message #330090 is a reply to message #330055] Mon, 14 July 2008 11:56 Go to previous message
Is there a reason why such a field is not accessible although it is
already implemented?
Extending the existing wizard is no good choice because the wizard is
already a New Project Wizard and the field mentioned above is the only
thing I need from the New Class Wizard.
> own page.
> Dani
>> Thank you so far
>> Lars Schneider
Previous Topic:implement my own debug, only one step over by thread and frame
Next Topic:How to programatically create a workspace
Current Time: Sun Nov 23 03:44:48 EST 2025
Powered by FUDForum. Page generated in 0.04166 seconds
