Home » Eclipse Projects » Eclipse Platform » Hyperlink as tableitem in jface/swt table
Hyperlink as tableitem in jface/swt table [message #330028] Sun, 13 July 2008 14:12 Go to next message
Originally posted by: zee.ali.gmail.com
I am trying to have one column of jface table as hyperlinks. I also
have 4 other columns of normal text strings using jface
columnlabelprovider to render the text on those columns.
One of the column which I want to display as hyperlink I dont use
ColumnLabelProvider for it, instead my columnlabelprovider just retruns
empty string for it. but I use the following way to insert hyperlinks
into it.
( in a for loop){
TableItem[] tableItems = table.getItems();//get tableItems
Hyperlink link = new Hyperlink(table, SWT.WRAP);
link.setText( some text);
TableEditor editor = new TableEditor(table);
editor.setEditor(link, tableItem[n], 0);//set hyperlinks in column 0
The issue with above approach is that if the width of hyperlink is
longer than the column it goes into next column. Where is the desired
behaviour is that it should show ellipsis(and tool tip of hidden text)
if it goes over the width of the column. Which is the normal behaviour
of other text string columns handled by jface columnlabelprovider.
The issue is that I couldnt find any jface interface for
columnlabelprovider which would return a widget instead of string for
its string getelement() method.
Any help would be greatly appreciated.
Zeeshan
Re: Hyperlink as tableitem in jface/swt table [message #330037 is a reply to message #330028] Sun, 13 July 2008 17:48 Go to previous messageGo to next message
You should use an owner draw label provider and draw the text to look
like a hyperlink [1] and act on the click event with a mouse-listener or
create an editor.
Tom
[1] http://wiki.eclipse.org/JFaceSnippets#Snippet049StyledCellLa belProvider
Zeeshan Ali schrieb:
> Hello,
> into it.
> ( in a for loop){
> Zeeshan
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Hyperlink as tableitem in jface/swt table [message #330097 is a reply to message #330037] Mon, 14 July 2008 16:29 Go to previous messageGo to next message
> create an editor.
> Tom
>> Hello,
>> retruns empty string for it. but I use the following way to insert
>> hyperlinks into it.
>> ( in a for loop){
>> Thanks,
>> Zeeshan
Thanks for your reply/advice. I will try that and update this posting to
let everyone know how did that go.
Re: Hyperlink as tableitem in jface/swt table [message #330099 is a reply to message #330037] Mon, 14 July 2008 19:13 Go to previous messageGo to next message
> create an editor.
> Tom
>> Hello,
>> hyperlinks into it.
>> ( in a for loop){
>> Thanks,
>> Zeeshan
Re: Hyperlink as tableitem in jface/swt table [message #330104 is a reply to message #330099] Tue, 15 July 2008 04:28 Go to previous messageGo to next message
If you have a small snippet I'd add it to our collection. It was not the
first time this Hyperlink-Question was asked.
Tom
>> or create an editor.
>> Tom
>>> Hello,
>>> hyperlinks into it.
>>> ( in a for loop){
>>> text) if it goes over the width of the column. Which is the normal
>>> behaviour of other text string columns handled by jface
>>> Thanks,
>>> Zeeshan
Re: Hyperlink as tableitem in jface/swt table [message #330141 is a reply to message #330037] Wed, 16 July 2008 14:11 Go to previous messageGo to next message
Thanks for your reply/suggestion. I will try this and post it here how
it goes.
> create an editor.
> Tom
>> Hello,
>> hyperlinks into it.
>> ( in a for loop){
>> Thanks,
>> Zeeshan
Re: Hyperlink as tableitem in jface/swt table [message #330142 is a reply to message #330104] Wed, 16 July 2008 14:13 Go to previous message
It will be a while till I implement it, for now my manager is happy with
a workaround of resizing the table column, which I did, but once I have
time eventually I will have to try your suggestion. Could be few months
before I try your suggestion.
> Tom
>>> Tom
>>>> Hello,
>>>> hyperlinks into it.
>>>> ( in a for loop){
>>>> desired behaviour is that it should show ellipsis(and tool tip of
>>>> hidden text) if it goes over the width of the column. Which is the
>>>> normal behaviour of other text string columns handled by jface
>>>> for its string getelement() method.
>>>> Thanks,
>>>> Zeeshan
Previous Topic:Handling passwords in CVS EFS
Next Topic:ID of default font for TableViewers
Current Time: Thu Jul 17 19:20:44 EDT 2025
Powered by FUDForum. Page generated in 0.27009 seconds
