Home » Eclipse Projects » Eclipse Platform » How to set dynamic text in splash screen
How to set dynamic text in splash screen [message #329952] Fri, 11 July 2008 05:39 Go to next message
I needs to put a text in the splash screen which will changes dynamically
how can i achieve this.
Example: when i have started the eclipse it displays the splash.bmp file,
likewise i have my own bmp file and wanted to display a dynamic text into
this. please help me.
-Hari
Re: How to set dynamic text in splash screen [message #329953 is a reply to message #329952] Fri, 11 July 2008 06:35 Go to previous messageGo to next message
On Fri, 11 Jul 2008 09:39:54 +0000 (UTC), haribabu2006@gmail.com
(HariBabu) wrote:
>Hi,
>Thanks
>-Hari
I tested this in Eclipse 3.4 but i think it is available in older
versions:
Open the "New Project..." wizard
Select the "Plug-in Project"
Set "Project name" and leave the other options alone
Advance to the "Templates" page
Select "Custom plug-in wizard", choose "Next"
Deselect all Templates and select the "Splash Handler" Template
Choose the kind of Splash screen you want on the next page
Finish
The generated plug-in might already fullfil your requirements.
Otherwise just modify it.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: How to set dynamic text in splash screen [message #329975 is a reply to message #329953] Fri, 11 July 2008 12:09 Go to previous messageGo to next message
Thanks it is working
Re: How to set dynamic text in splash screen [message #330049 is a reply to message #329975] Mon, 14 July 2008 04:53 Go to previous message
I have specified this splashHandlers extension in my product plugin's
extension and my message showing after some delay i.e.
The movement my splash screen started, its giving me a "Workspace
Launcher" dialog, if click on "ok" then only the splash message which i
have added is showing.
I need this message to show when the splash screen shown. Is it possible
or any constraints in this?.
Previous Topic:Using DLL in an Eclipse plugin
Next Topic:Re: Problem switching from Europa to Ganymede
Current Time: Fri Nov 21 02:53:23 EST 2025
Powered by FUDForum. Page generated in 0.04097 seconds
