Home » Eclipse Projects » Eclipse Platform » Re: Problem switching from Europa to Ganymede
Re: Problem switching from Europa to Ganymede [message #329891] Wed, 09 July 2008 13:24 Go to next message
Originally posted by: j4r0d.hotmail.com
I am still facing the same problem and I have found something weird.
When I use the "eclipse product export wizard" everything works fine and the
operation ends normally. But when I take a look at the output directory, in
the plugins folder I can see that only my packages where exported. Eclipse's
plugins are simply missing and so are my plugin (eclipse) dependances...
This may be the source of my problem... because when I try to run my plugin
rather than exporting it, it throws the ClassNotFoundException bellow...
I have also been able to run my plugin using the Run link from the
plugin.xml of the main plugin. So I guess that it is well possible to launch
a 3.4 run-time workbench from a 3.3 development workbench.
However here, I am a bit lost... what am I missing in my product
configuration (.product) file so I get the following stack trace when I hit
the "Launch an Eclipse Application" button??? Why does some part of the
exported product is missing???
!SESSION Wed Jul 09 19:14:54 CEST
2008 -----------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2008-07-09 19:14:54.187
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 546)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Please help!!!
Thanks a lot.
J.
"Christian W. Damus" wrote:
Hi, J,
The Eclipse Equinox platform has changed the way it is launched in the 3.4
release. If you are trying to launch a 3.4 run-time workbench from a 3.3
development workbench, then perhaps it simply won't work.
Have a look at the Equinox Wiki for a description of the changes.
HTH,
Christian
On Fri, 2008-07-04 at 15:17 +0200, Jarod Mills wrote:
I don't know what to do here since my plugin is not even called...
Do you know how I can solve this problem?
J.
Re: Problem switching from Europa to Ganymede [message #329892 is a reply to message #329891] Wed, 09 July 2008 13:44 Go to previous messageGo to next message
Did you include all required plugins on the configuration tab?
"Jarod Mills" <j4r0d@hotmail.com> wrote in message
news:g52sm3$her$1@build.eclipse.org...
> Hello,
> the operation ends normally. But when I take a look at the output
> directory, in the plugins folder I can see that only my packages where
> exported. Eclipse's plugins are simply missing and so are my plugin
> plugin rather than exporting it, it throws the ClassNotFoundException
> bellow...
> launch a 3.4 run-time workbench from a 3.3 development workbench.
> hit the "Launch an Eclipse Application" button??? Why does some part of
> the exported product is missing???
> !STACK
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> Please help!!!
> Thanks a lot.
> J.
> Hi, J,
> HTH,
> Christian
> Hello,
> J.
Re: Problem switching from Europa to Ganymede [message #329902 is a reply to message #329892] Thu, 10 July 2008 05:25 Go to previous messageGo to next message
Hi Lars,
I have included all the required plugins in my previous attempt, or at least
this configuration was working on europa.
My product ID is defined in a plugin.xml of one of my plugins. The
application selected is org.eclipse.ui.ide.workbench.
My product configuration is based on features.
I have tried adding every possible features here which leads to a different
error log...
My Product com.xxx.project.product.productMui is not found... so as many
bundles... what's going on?!
!SESSION 2008-07-10
11:10:26.546 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_02
Framework arguments: -product com.xxx.project.product.productMui
Command-line arguments: -product com.xxx.project.product.productMui -data
D:\Workspace3.4/../runtime-xxx-project.mui.product -dev
file:D:/Workspace3.4/.metadata/.plugins/org.eclipse.pde.core /xxx-project.mui.product/dev.properties -
os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2008-07-10 11:10:27.484
!MESSAGE Product com.xxx.project.product.productMui could not be found.
!ENTRY org.eclipse.osgi 4 0 2008-07-10 11:10:27.515
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
!ENTRY org.eclipse.osgi 2 0 2008-07-10 11:10:27.593
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.p2.ui_1.0.0.v20080604-2000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.p2.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.core.resources_[3.4.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. mduEditor/ was
not resolved.
!SUBENTRY 2 com.xxx.project.mduEditor 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.jface.text_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.gef_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.compare_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.cheatsheets_0.0.0.
!MESSAGE Missing required bundle org.eclipse.core.resources_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.editors_0.0.0.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.tig ris.subversion.subclipse.core_1.2.4.jar
was not resolved.
!SUBENTRY 2 org.tigris.subversion.subclipse.core 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.team.core_3.2.0.
!MESSAGE Missing required bundle org.eclipse.core.resources_3.2.0.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.mapping.ecore2xml.ui_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.4.0,4.0.0).
!MESSAGE Bundle reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project/
was not resolved.
!SUBENTRY 2 com.xxx.project 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.ui.console_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.launching_0.0.0.
!MESSAGE Missing required bundle org.eclipse.debug.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.debug.core_0.0.0.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.ui_3.4.0.v20080530.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.ui.cheatsheets_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.launching_[3.2.0,4.0.0).
org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.update.core_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.team.core_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.search_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ant.ui_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.core_[3.2.0,4.0.0).
org.eclipse.ltk.core.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.intro_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_[3.2.0,4.0.0).
org.eclipse.ltk.ui.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.junit_[3.2.0,4.0.0).
org.eclipse.ui.navigator.resources_[3.3.100,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.debug.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.compare_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.filesystem_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.jdt.debug.core_0.0.0.
org.eclipse.jdt.core.manipulation_[1.1.0,2.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.junit.runtime_3.4.0.v20080529-1800.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.junit.runtime 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.junit_[3.8.1,3.9.0).
org.eclipse.jdt.junit.runtime_[3.2.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.edit.ui_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.edit.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.3.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.api.tools_1.0.0.v20080529-1150.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.api.tools 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.jdt.core_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.launching_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.text_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.filebuffers_[3.4.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.api.tools.ui_1.0.0.v20080603.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.593
org.eclipse.ltk.core.refactoring_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.4.0,4.0.0).
org.eclipse.ltk.ui.refactoring_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.ui_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.search_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.4.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.importer.rose_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer.rose 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.codegen_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.debug.core_[3.4.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.tig ris.subversion.subclipse.ui_1.2.4.jar
was not resolved.
!SUBENTRY 2 org.tigris.subversion.subclipse.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.team.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.views_0.0.0.
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. product/ was not
resolved.
!SUBENTRY 2 com.xxx.project.product 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.ui.intro_0.0.0.
!MESSAGE Missing required bundle org.eclipse.update.ui_0.0.0.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.importer_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.build_3.4.0.v20080604/
was not resolved.
!SUBENTRY 2 org.eclipse.pde.build 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.update.core_[3.1.100,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/org.eclipse.jdt. launching.j9/
was not resolved.
!SUBENTRY 2 org.eclipse.jdt.launching.j9 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jdt.debug_0.0.0.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.ecore.editor_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.editor 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.codegen.ecore_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen.ecore 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.core_3.4.0.v20080604-2000.jar
was not resolved.
!SUBENTRY 2 org.eclipse.pde.core 2 0 2008-07-10 11:10:27.593
!MESSAGE Missing required bundle org.eclipse.text_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.filebuffers_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.resources_[3.2.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.mapping.ui_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ui 2 0 2008-07-10 11:10:27.593
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.importer.ecore_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer.ecore 2 0 2008-07-10 11:10:27.609
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.importer.java_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer.java 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.codegen.ui_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. mdcEditor/ was
not resolved.
!SUBENTRY 2 com.xxx.project.mdcEditor 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.codegen.ecore.ui_2.4.0.v200806091234.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen.ecore.ui 2 0 2008-07-10 11:10:27.609
!ENTRY org.eclipse.osgi 2 0 2008-07-10 11:10:27.609
!MESSAGE The following is a complete list of bundles which are not resolved,
see the prior log entry for the root cause if it exists:
!MESSAGE Bundle
[3] was not resolved.
!SUBENTRY 2 org.eclipse.pde.p2.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.pde.ui_[3.3.0,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.tig ris.subversion.javahl.win32_1.2.4/
[30] was not resolved.
!SUBENTRY 2 org.tigris.subversion.javahl.win32 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing host org.tigris.subversion.subclipse.core_1.2.4.
!MESSAGE Bundle
[31] was not resolved.
!SUBENTRY 2 org.eclipse.pde.build 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. mduEditor/ [33]
was not resolved.
!SUBENTRY 2 com.xxx.project.mduEditor 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.edit.ui_0.0.0.
!MESSAGE Missing required bundle com.xxx.project_0.0.0.
!MESSAGE Bundle
[40] was not resolved.
!SUBENTRY 2 org.eclipse.pde.api.tools 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.pde.core_[3.3.102,4.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.exporter_2.4.0.v200806091234.jar
[46] was not resolved.
!SUBENTRY 2 org.eclipse.emf.exporter 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.converter_[2.4.0,3.0.0).
!MESSAGE Missing optionally required bundle
org.eclipse.emf.codegen.ecore.ui_[2.4.0,3.0.0).
!MESSAGE Bundle
[47] was not resolved.
!MESSAGE Missing required bundle org.eclipse.emf.importer_[2.4.0,3.0.0).
org.eclipse.emf.ant_[2.4.0,3.0.0).
!MESSAGE Bundle
[50] was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen.ecore 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.codegen_[2.4.0,3.0.0).
!MESSAGE Bundle
[51] was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.editor 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.edit.ui_[2.4.0,3.0.0).
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.pde.ui.templates_3.4.0.v20080514-1500.jar
[52] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui.templates 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[56] was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[59] was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.mapping.ecore2ecore.editor_2.4.0.v200806091234.jar
[60] was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore.editor 2 0 2008-07-10
11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.mapping.ui_[2.4.0,3.0.0).
11:10:27.609
!MESSAGE Missing required bundle org.eclipse.emf.ecore.editor_[2.4.0,3.0.0).
!MESSAGE Bundle
[69] was not resolved.
org.eclipse.emf.codegen.ecore_[2.4.0,3.0.0).
!MESSAGE Bundle
[70] was not resolved.
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.converter_2.4.0.v200806091234.jar
[73] was not resolved.
!SUBENTRY 2 org.eclipse.emf.converter 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[75] was not resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.pde.core_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.pde.build_[3.2.0,4.0.0).
!MESSAGE Bundle
[77] was not resolved.
!SUBENTRY 2 org.tigris.subversion.subclipse.core 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[82] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.launching.j9 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. product/ [83]
was not resolved.
!SUBENTRY 2 com.xxx.project.product 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. lang.fr/ [84]
was not resolved.
!SUBENTRY 2 com.xxx.project.lang.fr 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing host com.xxx.project_1.0.0.
!MESSAGE Bundle
[85] was not resolved.
!SUBENTRY 2 org.eclipse.pde.core 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.eclipse.pde.build_[3.2.0,4.1.0).
!MESSAGE Bundle
[94] was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[95] was not resolved.
!SUBENTRY 2 org.eclipse.pde.junit.runtime 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
reference:file:/D:/Programs/eclipse-ganymede/plugins/org.ecl ipse.emf.ant_2.4.0.v200806091234.jar
[113] was not resolved.
!SUBENTRY 2 org.eclipse.emf.ant 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[114] was not resolved.
!SUBENTRY 2 org.eclipse.emf.mapping.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Bundle
[122] was not resolved.
!SUBENTRY 2 org.tigris.subversion.subclipse.ui 2 0 2008-07-10 11:10:27.609
!MESSAGE Missing required bundle org.tigris.subversion.subclipse.core_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.jdt.ui_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.jdt.core_0.0.0.
!MESSAGE Bundle
[123] was not resolved.
!SUBENTRY 2 org.eclipse.emf.edit.ui 2 0 2008-07-10 11:10:27.625
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.625
!MESSAGE Bundle
[125] was not resolved.
!SUBENTRY 2 org.eclipse.emf.importer.rose 2 0 2008-07-10 11:10:27.625
[127] was not resolved.
!SUBENTRY 2 com.xxx.project 2 0 2008-07-10 11:10:27.625
!MESSAGE Missing required bundle org.eclipse.jdt.launching.j9_0.0.0.
!MESSAGE Bundle
[128] was not resolved.
!SUBENTRY 2 org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.625
!MESSAGE Missing required bundle org.eclipse.pde.ui_[3.4.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.pde.api.tools_[1.0.0,2.0.0).
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. fw.windows/
[140] was not resolved.
!SUBENTRY 2 com.xxx.project.fw.windows 2 0 2008-07-10 11:10:27.625
!MESSAGE Bundle
[141] was not resolved.
!SUBENTRY 2 org.eclipse.emf.codegen.ui 2 0 2008-07-10 11:10:27.625
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. fw.linux/ [142]
was not resolved.
!SUBENTRY 2 com.xxx.project.fw.linux 2 0 2008-07-10 11:10:27.625
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.obfuscator.p roGuard.config/
[143] was not resolved.
!SUBENTRY 2 com.obfuscator.proGuard.config 2 0 2008-07-10 11:10:27.625
!MESSAGE Bundle
reference:file:/D:/Workspace3.4/2.X-project/com.xxx.project. mdcEditor/ [148]
was not resolved.
!SUBENTRY 2 com.xxx.project.mdcEditor 2 0 2008-07-10 11:10:27.625
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:g52td5$s1r$1@build.eclipse.org...
>> Hello,
>> bellow...
>> !STACK
>> Please help!!!
>> Thanks a lot.
>> J.
>> Hi, J,
>> 3.4 release. If you are trying to launch a 3.4 run-time workbench from a
>> 3.3 development workbench, then perhaps it simply won't work.
>> HTH,
>> Christian
>> Hello,
Re: Problem switching from Europa to Ganymede [message #330060 is a reply to message #329902] Mon, 14 July 2008 05:53 Go to previous message
I had a similar problem, this helped me: remove and add the features
again in your product. 3.4 does probably not find 3.3 features.
greetings,
Manuel
Jarod Mills wrote:
> Hi Lars,
> at least this configuration was working on europa. My product ID is
> defined in a plugin.xml of one of my plugins. The application
> selected is org.eclipse.ui.ide.workbench. My product configuration
> different error log...
> many bundles... what's going on?!
> !SESSION 2008-07-10 11:10:26.546
> eclipse.buildId=unknown java.version=1.6.0_02
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> -data D:\Workspace3.4/../runtime-xxx-project.mui.product -dev
> ct.mui.product/dev.properties - os win32 -ws win32 -arch x86 !ENTRY
> org.eclipse.equinox.app 0 0 2008-07-10 11:10:27.484 !MESSAGE Product
> com.xxx.project.product.productMui could not be found. !ENTRY
> org.eclipse.osgi 4 0 2008-07-10 11:10:27.515 !MESSAGE Application
> error !STACK 1 java.lang.RuntimeException: No application id has been
> found. at
> clipseAppContainer.java:236) at
> cationLauncher.java:29) at
> ation(EclipseAppLauncher.java:110) at
> ipseAppLauncher.java:79) at
> a:382) at
> a:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
> java.lang.reflect.Method.invoke(Unknown Source) at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) at
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at
> org.eclipse.equinox.launcher.Main.run(Main.java:1236) at
> org.eclipse.equinox.launcher.Main.main(Main.java:1212) !ENTRY
> org.eclipse.osgi 2 0 2008-07-10 11:10:27.593 !MESSAGE One or more
> bundles are not resolved because the following root constraints are
> not resolved: !SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10
> 11:10:27.593 !MESSAGE Bundle
> 2.ui_1.0.0.v20080604-2000.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.p2.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.core.resources_[3.4.0,4.0.0). !SUBENTRY
> 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.593 !MESSAGE Bundle
> was not resolved. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> 2008-07-10 11:10:27.593 !MESSAGE Missing required bundle
> org.eclipse.jface.text_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor
> 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing required bundle
> org.eclipse.jdt.ui_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> org.eclipse.gef_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> org.eclipse.jdt.core_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor 2
> org.eclipse.compare_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> org.eclipse.ui.ide_0.0.0. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> org.eclipse.ui.cheatsheets_0.0.0. !SUBENTRY 2
> com.xxx.project.mduEditor 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.core.resources_0.0.0. !SUBENTRY
> 2 com.xxx.project.mduEditor 2 0 2008-07-10 11:10:27.593 !MESSAGE
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> sion.subclipse.core_1.2.4.jar was not resolved. !SUBENTRY 2
> org.eclipse.core.resources_3.2.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> apping.ecore2xml.ui_2.4.0.v200806091234.jar was not resolved.
> org.eclipse.core.resources_[3.4.0,4.0.0). !SUBENTRY 2
> was not resolved. !SUBENTRY 2 com.xxx.project 2 0 2008-07-10
> org.eclipse.ui.editors_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.core.resources_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.ui.console_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.ui.cheatsheets_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.jdt.core_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.ui.workbench.texteditor_0.0.0. !SUBENTRY 2
> com.xxx.project 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing required
> bundle org.eclipse.jdt.launching_0.0.0. !SUBENTRY 2 com.xxx.project
> org.eclipse.debug.ui_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.jface.text_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.jdt.ui_0.0.0. !SUBENTRY 2 com.xxx.project 2 0 2008-07-10
> org.eclipse.ui.ide_0.0.0. !SUBENTRY 2 com.xxx.project 2 0 2008-07-10
> org.eclipse.debug.core_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> i_3.4.0.v20080530.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.ui.cheatsheets_[3.2.0,4.0.0). !SUBENTRY
> 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.jdt.launching_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
> !SUBENTRY 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.search_[3.1.0,4.0.0). !SUBENTRY
> required bundle org.eclipse.ui.views_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.ui.ide_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.jface.text_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.ant.ui_[3.1.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.jdt.core_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.ltk.core.refactoring_[3.2.0,4.0.0).
> Missing required bundle org.eclipse.ltk.ui.refactoring_[3.2.0,4.0.0).
> org.eclipse.ui.navigator.resources_[3.3.100,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.jdt.ui_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.debug.ui_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.compare_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.core.filesystem_[1.0.0,2.0.0). !SUBENTRY
> imported package org.eclipse.jdt.debug.core_0.0.0. !SUBENTRY 2
> required bundle org.eclipse.jdt.core.manipulation_[1.1.0,2.0.0).
> Bundle
> unit.runtime_3.4.0.v20080529-1800.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.junit.runtime 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.junit_[3.8.1,3.9.0). !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.junit.runtime_[3.2.0,4.0.0).
> Bundle
> dit.ui_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.edit.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.ui.views_[3.3.0,4.0.0). !SUBENTRY 1
> pi.tools_1.0.0.v20080529-1150.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.api.tools 2 0 2008-07-10 11:10:27.593 !MESSAGE
> org.eclipse.core.filebuffers_[3.4.0,4.0.0). !SUBENTRY 1
> pi.tools.ui_1.0.0.v20080603.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE
> org.eclipse.ltk.core.refactoring_[3.4.0,4.0.0). !SUBENTRY 2
> org.eclipse.ltk.ui.refactoring_[3.4.0,4.0.0). !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.ui_[3.4.0,4.0.0). !SUBENTRY
> 2 org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.search_[3.4.0,4.0.0). !SUBENTRY
> Bundle
> mporter.rose_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.importer.rose 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> odegen_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.jdt.core_[3.4.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.debug.core_[3.4.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.text_[3.4.0,4.0.0). !SUBENTRY 2
> 2 org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> sion.subclipse.ui_1.2.4.jar was not resolved. !SUBENTRY 2
> org.eclipse.team.core_3.2.0. !SUBENTRY 2
> org.eclipse.ui.views_0.0.0. !SUBENTRY 2
> org.eclipse.core.resources_3.2.0. !SUBENTRY 2
> Bundle
> was not resolved. !SUBENTRY 2 com.xxx.project.product 2 0 2008-07-10
> org.eclipse.ui.intro_0.0.0. !SUBENTRY 2 com.xxx.project.product 2 0
> org.eclipse.update.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> mporter_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.importer 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> uild_3.4.0.v20080604/ was not resolved. !SUBENTRY 2
> org.eclipse.pde.build 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.update.core_[3.1.100,4.0.0). !SUBENTRY 1
> j9/ was not resolved. !SUBENTRY 2 org.eclipse.jdt.launching.j9 2 0
> org.eclipse.jdt.debug.ui_0.0.0. !SUBENTRY 2
> org.eclipse.jdt.launching.j9 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.debug.core_0.0.0. !SUBENTRY 2
> 2 org.eclipse.jdt.launching.j9 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.ui.ide_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.core_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.debug_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.launching_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.debug.ui_0.0.0. !SUBENTRY 1
> core.editor_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.ecore.editor 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> odegen.ecore_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.codegen.ecore 2 0 2008-07-10 11:10:27.593 !MESSAGE
> org.eclipse.jdt.launching_[3.4.0,4.0.0). !SUBENTRY 2
> Missing required bundle org.eclipse.text_[3.4.0,4.0.0). !SUBENTRY 2
> Bundle
> ore_3.4.0.v20080604-2000.jar was not resolved. !SUBENTRY 2
> org.eclipse.pde.core 2 0 2008-07-10 11:10:27.593 !MESSAGE Missing
> required bundle org.eclipse.team.core_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.text_[3.1.0,4.0.0). !SUBENTRY 2
> !SUBENTRY 2 org.eclipse.pde.core 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> apping.ui_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.mapping.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Missing required bundle org.eclipse.ui.ide_[3.4.0,4.0.0). !SUBENTRY
> 2 org.eclipse.emf.mapping.ui 2 0 2008-07-10 11:10:27.593 !MESSAGE
> Bundle
> mporter.ecore_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.importer.ecore 2 0 2008-07-10 11:10:27.609 !MESSAGE
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Bundle
> mporter.java_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.importer.java 2 0 2008-07-10 11:10:27.609 !MESSAGE
> org.eclipse.core.resources_[3.4.0,4.0.0). !SUBENTRY 1
> org.eclipse.osgi 2 0 2008-07-10 11:10:27.609 !MESSAGE Bundle
> odegen.ui_2.4.0.v200806091234.jar was not resolved. !SUBENTRY 2
> org.eclipse.emf.codegen.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Bundle
> was not resolved. !SUBENTRY 2 com.xxx.project.mdcEditor 2 0
> 2008-07-10 11:10:27.609 !MESSAGE Missing required bundle
> com.xxx.project.mdcEditor 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Missing required bundle org.eclipse.ui.ide_0.0.0. !SUBENTRY 1
> odegen.ecore.ui_2.4.0.v200806091234.jar was not resolved. !SUBENTRY
> org.eclipse.ui.ide_[3.4.0,4.0.0). !SUBENTRY 2
> org.eclipse.emf.codegen.ecore.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE
> !ENTRY org.eclipse.osgi 2 0 2008-07-10 11:10:27.609 !MESSAGE The
> following is a complete list of bundles which are not resolved, see
> the prior log entry for the root cause if it exists: !SUBENTRY 1
> 2.ui_1.0.0.v20080604-2000.jar [3] was not resolved. !SUBENTRY 2
> org.eclipse.pde.p2.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> 2 org.eclipse.pde.p2.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.pde.ui_[3.3.0,4.0.0). !SUBENTRY 1
> sion.javahl.win32_1.2.4/ [30] was not resolved. !SUBENTRY 2
> Bundle
> uild_3.4.0.v20080604/ [31] was not resolved. !SUBENTRY 2
> org.eclipse.pde.build 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> [33] was not resolved. !SUBENTRY 2 com.xxx.project.mduEditor 2 0
> com.xxx.project.mduEditor 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Missing required bundle org.eclipse.emf.edit.ui_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.ui.editors_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.ui_0.0.0. !SUBENTRY 2
> !MESSAGE Missing required bundle org.eclipse.gef_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.compare_0.0.0. !SUBENTRY 2
> Missing required bundle com.xxx.project_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.ui.cheatsheets_0.0.0. !SUBENTRY
> 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.609 !MESSAGE Bundle
> pi.tools_1.0.0.v20080529-1150.jar [40] was not resolved. !SUBENTRY 2
> org.eclipse.pde.api.tools 2 0 2008-07-10 11:10:27.609 !MESSAGE
> xporter_2.4.0.v200806091234.jar [46] was not resolved. !SUBENTRY 2
> org.eclipse.emf.exporter 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.emf.converter_[2.4.0,3.0.0). !SUBENTRY 2
> optionally required bundle org.eclipse.core.resources_[3.4.0,4.0.0).
> org.eclipse.emf.codegen.ecore.ui_[2.4.0,3.0.0). !SUBENTRY 1
> mporter.ecore_2.4.0.v200806091234.jar [47] was not resolved.
> 11:10:27.609 !MESSAGE Missing optionally required bundle
> org.eclipse.emf.codegen.ecore.ui_[2.4.0,3.0.0). !SUBENTRY 2
> Missing optionally required bundle org.eclipse.emf.ant_[2.4.0,3.0.0).
> Bundle
> odegen.ecore_2.4.0.v200806091234.jar [50] was not resolved.
> org.eclipse.emf.codegen.ecore 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Bundle
> core.editor_2.4.0.v200806091234.jar [51] was not resolved. !SUBENTRY
> 2 org.eclipse.emf.ecore.editor 2 0 2008-07-10 11:10:27.609 !MESSAGE
> org.eclipse.emf.edit.ui_[2.4.0,3.0.0). !SUBENTRY 1 org.eclipse.osgi
> i.templates_3.4.0.v20080514-1500.jar [52] was not resolved.
> Bundle
> mporter_2.4.0.v200806091234.jar [56] was not resolved. !SUBENTRY 2
> org.eclipse.emf.importer 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> 2 org.eclipse.emf.importer 2 0 2008-07-10 11:10:27.609 !MESSAGE
> apping.ecore2xml.ui_2.4.0.v200806091234.jar [59] was not resolved.
> org.eclipse.emf.edit.ui_[2.4.0,3.0.0). !SUBENTRY 2
> Bundle
> apping.ecore2ecore.editor_2.4.0.v200806091234.jar [60] was not
> resolved. !SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore.editor 2 0
> org.eclipse.emf.mapping.ui_[2.4.0,3.0.0). !SUBENTRY 2
> org.eclipse.emf.ecore.editor_[2.4.0,3.0.0). !SUBENTRY 1
> odegen.ecore.ui_2.4.0.v200806091234.jar [69] was not resolved.
> Missing required bundle org.eclipse.emf.codegen.ecore_[2.4.0,3.0.0).
> mporter.java_2.4.0.v200806091234.jar [70] was not resolved.
> org.eclipse.emf.importer_[2.4.0,3.0.0). !SUBENTRY 2
> Bundle
> onverter_2.4.0.v200806091234.jar [73] was not resolved. !SUBENTRY 2
> org.eclipse.emf.converter 2 0 2008-07-10 11:10:27.609 !MESSAGE
> i_3.4.0.v20080530.jar [75] was not resolved. !SUBENTRY 2
> org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.pde.core_[3.2.0,4.0.0). !SUBENTRY 2
> !SUBENTRY 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Missing required bundle org.eclipse.jdt.ui_[3.2.0,4.0.0). !SUBENTRY
> 2 org.eclipse.pde.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.pde.build_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.search_[3.1.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.update.core_[3.1.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.jdt.junit_[3.2.0,4.0.0). !SUBENTRY 2
> required bundle org.eclipse.ui.intro_[3.2.0,4.0.0). !SUBENTRY 2
> Missing required bundle org.eclipse.compare_[3.2.0,4.0.0). !SUBENTRY
> org.eclipse.jdt.core.manipulation_[1.1.0,2.0.0). !SUBENTRY 2
> required bundle org.eclipse.ui.navigator.resources_[3.3.100,4.0.0).
> Missing imported package org.eclipse.jdt.debug.core_0.0.0. !SUBENTRY
> sion.subclipse.core_1.2.4.jar [77] was not resolved. !SUBENTRY 2
> org.eclipse.team.core_3.2.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> j9/ [82] was not resolved. !SUBENTRY 2 org.eclipse.jdt.launching.j9
> 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing required bundle
> org.eclipse.jdt.launching.j9 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Missing required bundle org.eclipse.debug.ui_0.0.0. !SUBENTRY 2
> Missing required bundle org.eclipse.jdt.debug.ui_0.0.0. !SUBENTRY 2
> [83] was not resolved. !SUBENTRY 2 com.xxx.project.product 2 0
> [84] was not resolved. !SUBENTRY 2 com.xxx.project.lang.fr 2 0
> 2008-07-10 11:10:27.609 !MESSAGE Missing host com.xxx.project_1.0.0.
> Bundle
> ore_3.4.0.v20080604-2000.jar [85] was not resolved. !SUBENTRY 2
> org.eclipse.pde.core 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.core.resources_[3.2.0,4.0.0). !SUBENTRY
> 2 org.eclipse.pde.core 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> !SUBENTRY 2 org.eclipse.pde.core 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Bundle
> odegen_2.4.0.v200806091234.jar [94] was not resolved. !SUBENTRY 2
> org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> 2 org.eclipse.emf.codegen 2 0 2008-07-10 11:10:27.609 !MESSAGE
> required bundle org.eclipse.text_[3.4.0,4.0.0). !SUBENTRY 1
> unit.runtime_3.4.0.v20080529-1800.jar [95] was not resolved.
> org.eclipse.jdt.junit.runtime_[3.2.0,4.0.0). !SUBENTRY 2
> org.eclipse.pde.junit.runtime 2 0 2008-07-10 11:10:27.609 !MESSAGE
> Missing required bundle org.junit_[3.8.1,3.9.0). !SUBENTRY 1
> nt_2.4.0.v200806091234.jar [113] was not resolved. !SUBENTRY 2
> org.eclipse.emf.ant 2 0 2008-07-10 11:10:27.609 !MESSAGE Missing
> required bundle org.eclipse.emf.codegen_[2.4.0,3.0.0). !SUBENTRY 2
> org.eclipse.emf.codegen.ecore_[2.4.0,3.0.0). !SUBENTRY 1
> apping.ui_2.4.0.v200806091234.jar [114] was not resolved. !SUBENTRY
> 2 org.eclipse.emf.mapping.ui 2 0 2008-07-10 11:10:27.609 !MESSAGE
> sion.subclipse.ui_1.2.4.jar [122] was not resolved. !SUBENTRY 2
> org.tigris.subversion.subclipse.core_0.0.0. !SUBENTRY 2
> !MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0. !SUBENTRY
> org.eclipse.team.ui_0.0.0. !SUBENTRY 2
> org.eclipse.jdt.core_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> dit.ui_2.4.0.v200806091234.jar [123] was not resolved. !SUBENTRY 2
> org.eclipse.emf.edit.ui 2 0 2008-07-10 11:10:27.625 !MESSAGE Missing
> required bundle org.eclipse.ui.views_[3.3.0,4.0.0). !SUBENTRY 2
> org.eclipse.ui.ide_[3.4.0,4.0.0). !SUBENTRY 1 org.eclipse.osgi 2 0
> 2008-07-10 11:10:27.625 !MESSAGE Bundle
> mporter.rose_2.4.0.v200806091234.jar [125] was not resolved.
> org.eclipse.emf.importer.rose 2 0 2008-07-10 11:10:27.625 !MESSAGE
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.625 !MESSAGE
> [127] was not resolved. !SUBENTRY 2 com.xxx.project 2 0 2008-07-10
> 11:10:27.625 !MESSAGE Missing required bundle
> 2008-07-10 11:10:27.625 !MESSAGE Missing required bundle
> com.xxx.project 2 0 2008-07-10 11:10:27.625 !MESSAGE Missing required
> bundle org.eclipse.jface.text_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.debug.core_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.jdt.launching_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.jdt.launching.j9_0.0.0. !SUBENTRY 2 com.xxx.project 2 0
> org.eclipse.ui.cheatsheets_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2 0
> pi.tools.ui_1.0.0.v20080603.jar [128] was not resolved. !SUBENTRY 2
> org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.625 !MESSAGE
> org.eclipse.pde.api.tools_[1.0.0,2.0.0). !SUBENTRY 2
> 2 org.eclipse.pde.api.tools.ui 2 0 2008-07-10 11:10:27.625 !MESSAGE
> org.eclipse.ui.editors_[3.4.0,4.0.0). !SUBENTRY 2
> Missing required bundle org.eclipse.ltk.ui.refactoring_[3.4.0,4.0.0).
> Bundle
> / [140] was not resolved. !SUBENTRY 2 com.xxx.project.fw.windows 2 0
> 2008-07-10 11:10:27.625 !MESSAGE Missing host com.xxx.project_1.0.0.
> Bundle
> odegen.ui_2.4.0.v200806091234.jar [141] was not resolved. !SUBENTRY
> 2 org.eclipse.emf.codegen.ui 2 0 2008-07-10 11:10:27.625 !MESSAGE
> 1 org.eclipse.osgi 2 0 2008-07-10 11:10:27.625 !MESSAGE Bundle
> [142] was not resolved. !SUBENTRY 2 com.xxx.project.fw.linux 2 0
> Bundle
> nfig/ [143] was not resolved. !SUBENTRY 2
> com.obfuscator.proGuard.config 2 0 2008-07-10 11:10:27.625 !MESSAGE
Previous Topic:How to set dynamic text in splash screen
Next Topic:Plugin binary folder cause dependent plugins export to fail
Current Time: Mon Nov 03 23:19:40 EST 2025
Powered by FUDForum. Page generated in 0.08091 seconds
