Home » Eclipse Projects » Eclipse Platform » Using eclipse launch framework
Using eclipse launch framework [message #329878] Wed, 09 July 2008 02:22 Go to next message
I am using eclipse launch framework for my GUI.
I have followed all the steps given here:
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
I am able to see all my tabs and controls when i select my configuration
but I dont know how to configure Run button to execute my code.
Do we have any similar method like performApply()?
Also, i need to make Apply button ebabled on some event. How to make it
enabled in my selectionListner?
Also, need a help on how to retrieve all the configurations saved in
launch context programatically on any IAction.
Like hibernate has its own launch configuration, can we have our own
launch configuration and configurationType? if yes how?
Can anyone help?
Trushna
Re: Using eclipse launch framework [message #329912 is a reply to message #329878] Thu, 10 July 2008 09:43 Go to previous messageGo to next message
"T" <trush_b@yahoo.com> wrote in message
news:3e0bae75f9e563ee7f72aab9bc91a9ca$1@www.eclipse.org...
Need a class that implements ILaunchConfigurationDelegate. In the overridden
"launch" method write your code
Use the setDirty(boolean) and updateLaunchConfigurationDialog methods
What do you intend to do here exactly? In case you want this information
available to your Delegate class for the LaunchConfiguration, then it gets a
working copy of the LaunchConfiguration object with the values saved from
the Tab. You can use this object.
Rahul
> Can anyone help?
> Thanks Trushna
Re: Using eclipse launch framework [message #329941 is a reply to message #329912] Thu, 10 July 2008 18:35 Go to previous messageGo to next message
Have you created a launch configuration shortcut as described on that page?
Re: Using eclipse launch framework [message #329942 is a reply to message #329941] Fri, 11 July 2008 00:37 Go to previous messageGo to next message
Originally posted by: trushna.kholgade.xxxx.com
yes i did. actually writing code to be executed i launch method worked.
Thanks a lot for the reply.
Re: Using eclipse launch framework [message #329944 is a reply to message #329941] Fri, 11 July 2008 01:03 Go to previous messageGo to next message
I am able to customise Run button by overriding launch method in
Aply button also worked calling updateLaunchConfigurationDialog() on
listner.
I could retrieve all the configurations which i created through my launch
dialog using :
ILaunchConfigurationType type =
DebugPlugin.getDefault().getLaunchManager().getLaunchConfigu rationType( "id
of my config type");
ILaunchConfiguration[] configs =
DebugPlugin.getDefault().getLaunchManager().getLaunchConfigu rations(type);
Also i was able to get fully customised launch dialog by adding
'org.eclipse.debug.ui.launchGroups' and other needed extensions. and
specifying customised 'category' i.e. other that run or debug for
'org.eclipse.debug.core.launchConfigurationTypes' and
'org.eclipse.debug.ui.launchGroups' extensions.
Re: Using eclipse launch framework [message #329947 is a reply to message #329944] Fri, 11 July 2008 03:04 Go to previous messageGo to next message
Great! :)
I didn't know of
So something I got to know as well!
Rahul
"T" <trushna.kholgade@amdocs.com> wrote in message
news:36d5e114ace28e3367acda674b6c24c1$1@www.eclipse.org...
> listner.
> dialog using :
Re: Using eclipse launch framework [message #329995 is a reply to message #329947] Fri, 11 July 2008 14:13 Go to previous messageGo to next message
Did you guys understand what the difference is between a
LaunchConfigurationType and a LaunchConfigurationGroup?
At one time I had my launch config type showing up in Run and Debug
configuration UIs. But now they don't show. Any hints on how to debug this?
Rahul Kamdar wrote:
> Great! :)
> I didn't know of
> Rahul
>> listner.
>> dialog using :
Re: Using eclipse launch framework [message #330044 is a reply to message #329995] Mon, 14 July 2008 04:42 Go to previous messageGo to next message
LaunchConfigurationType is the description of how to launch a
program/application; while these configuration types sit under a
LaunchConfigurationGroup. The group is basically the placeholder for these
types in the Run/Debug menu (I think).
What was/is the problem you were encountering exactly?
Rahul
"John J Barton" <johnjbarton@johnjbarton.com> wrote in message
news:g587f3$vq7$1@build.eclipse.org...
> this?
> Rahul Kamdar wrote:
>> Great! :)
>> I didn't know of
>> Rahul
>>> Hi,
>>> listner.
>>> launch dialog using :
Re: Using eclipse launch framework [message #330094 is a reply to message #330044] Mon, 14 July 2008 14:36 Go to previous messageGo to next message
So then what is a "category" on the LaunchConfigurationType? I thought
that the category was the thing the types would sit under...
I had put my LaunchConfigurationType under a non-existent category. Once
I removed the category, the type appeared, yay!
> Rahul
>> this?
>> Rahul Kamdar wrote:
>>> Great! :)
>>> I didn't know of
>>> Rahul
>>>> Hi,
>>>> listner.
Re: Using eclipse launch framework [message #330436 is a reply to message #330094] Mon, 28 July 2008 15:33 Go to previous message
Hi John,
I am really sorry for having read this so late.
news:g5g5sv$cuh$1@build.eclipse.org...
>> these types in the Run/Debug menu (I think).
Rahul: Hmm... I am also pretty unsure of this now :( You could try posting
this as a new topic?
> I had put my LaunchConfigurationType under a non-existent category. Once I
Rahul: Great! :)
>> Rahul
>>> this?
>>> Rahul Kamdar wrote:
>>>> Great! :)
>>>> I didn't know of
>>>> Rahul
>>>>> Hi,
>>>>> listner.
Previous Topic:"Open" menu action in Project Explorer
Next Topic:Modifying Menu inside Job/Display.asyncExec()
Current Time: Sun Nov 02 17:21:37 EST 2025
Powered by FUDForum. Page generated in 0.26541 seconds
