Home » Eclipse Projects » Eclipse Platform » PDE build under Linux
PDE build under Linux [message #329863] Tue, 08 July 2008 13:39
I have problems to build a product under Linux x86_64. My product build
works fine under Windows XP. Now I tried to run the same scripts under
Linux and then I got following error message:
[java] Buildfile:
/a/geier/geier/ci/.hudson/jobs/abas-ERP_ScreenEditor/workspa ce/binaries/eclipse/eclipse/plugins/org.eclipse.pde.build_3. 4.0.v20080604/scripts/productBuild/productBuild.xml
[java]
[java] BUILD FAILED
[java]
/a/geier/geier/ci/.hudson/jobs/abas-ERP_ScreenEditor/workspa ce/binaries/eclipse/eclipse/plugins/org.eclipse.pde.build_3. 4.0.v20080604/scripts/productBuild/productBuild.xml:8:
Cannot find ${eclipse.pdebuild.scripts}/build.xml imported from
[java]
[java] Total time: 0 seconds
[antcall] Exiting
/a/geier/geier/ci/.hudson/jobs/abas-ERP_ScreenEditor/workspa ce/source/config/build.xml.
I used the Ant task <java> within Hudson as follows:
<java fork="true" failonerror="true"
jar=" ${eclipse.base.dir}/eclipse/plugins/org.eclipse.equinox.laun cher_1.0.100.v20080509-1800.jar ">
<arg value="-application" />
<arg value="org.eclipse.ant.core.antRunner" />
<arg value="-buildfile" />
<arg
value=" ${eclipse.base.dir}/eclipse/plugins/org.eclipse.pde.build_3. 4.0.v20080604/scripts/productBuild/productBuild.xml "
<arg value="-Dbuilder=${config.dir}" />
</java>
This worked fine under Windows but not under Linux.
The error is: Cannot find ${eclipse.pdebuild.scripts}/build.xml imported
from ...
Why is the property eclipse.pdebuild.scripts not set?
What did I do wrong? Does somebody know what I have to change?
With regards
Udo
Previous Topic:Adding the CommonNavigator PopupMenu to my View
Next Topic:Removing menu items that were added by org.eclipse.search
Current Time: Tue Jul 22 11:11:32 EDT 2025
Powered by FUDForum. Page generated in 0.06083 seconds
