| Home » Eclipse Projects » Eclipse Platform » create ANT builder programmatically
 Goto Forum:|
| create ANT builder programmatically [message #329829] | Mon, 07 July 2008 10:37  |  |
| Eclipse User  |  |  |  |  | Originally posted by: aurelrunner.hotmail.com
 I want to create programmatically an ANT builder.
 The same as right click on project node-> properties -> builders -> new...
 -> ANT builder
 I can add a builder with :
 private void addBuilder(IProject project, String id) {
 IProjectDescription desc;
 try {
 desc = project.getDescription();
 ICommand[] commands = desc.getBuildSpec();
 for (int i = 0; i < commands.length; ++i)
 if (commands[i].getBuilderName().equals(id))
 return;
 //add builder to project
 ICommand command = desc.newCommand();
 command.setBuilderName(id);
 ICommand[] nc = new ICommand[commands.length + 1];
 // Add it before other builders.
 System.arraycopy(commands, 0, nc, 1, commands.length);
 nc[0] = command;
 desc.setBuildSpec(nc);
 project.setDescription(desc, null);
 } catch (CoreException e) {
 e.printStackTrace();
 but i've a missing builder when I look at right click on project node->
 thanks for any help
| Re: create ANT builder programmatically [message #330525 is a reply to message #330443] | Thu, 31 July 2008 09:34  |  |
 Hi again,
 I can add builder!! (youpi)
 But I have issues with classpath.
 So, first I add a builder with the following code:
 /*create a ILaunchConfigurationWorkingCopy*/
 ILaunchManager launchManager = DebugPlugin.getDefault().getLaunchManager();
 ILaunchConfigurationType antType =
 launchManager.getLaunchConfigurationType(IAntLaunchConfigura tionConstants.ID_ANT_LAUNCH_CONFIGURATION_TYPE);
 String name = launchManager
 .generateUniqueLaunchConfigurationNameFrom(
 aProject.getName());
 ILaunchConfigurationWorkingCopy workingCopy =
 antType.newInstance(BuilderUtils.getBuilderFolder(aProject, true), name);
 /*add it parameters, all are not needed*/
 workingCopy.setAttribute( DebugPlugin.ATTR_CAPTURE_OUTPUT, true);
 workingCopy.setAttribute( IExternalToolConstants.ATTR_SHOW_CONSOLE,
 true);
 workingCopy.setAttribute(IAntLaunchConfigurationConstants.AT TR_TARGETS_UPDATED,
 true);
 workingCopy.setAttribute("org.eclipse.ant.ui.DEFAULT_VM_INSTALL ", true);
 workingCopy.setAttribute(IExternalToolConstants.ATTR_RUN_BUI LD_KINDS,
 "auto,full,incremental");
 workingCopy.setAttribute(IExternalToolConstants.BUILD_TYPE_A UTO, true);
 workingCopy.setAttribute(IExternalToolConstants.BUILD_TYPE_F ULL, true);
 workingCopy.setAttribute(IExternalToolConstants.BUILD_TYPE_I NCREMENTAL,
 true);
 workingCopy.setAttribute( IExternalToolConstants.ATTR_LOCATION,
 aProject.getLocation().append("build.xml").toOSString());
 workingCopy.setAttribute( IExternalToolConstants.ATTR_WORKING_DIRECTORY,
 aProject.getLocation().toOSString());
 workingCopy.setAttribute( IDebugUIConstants.ATTR_LAUNCH_IN_BACKGROUND,
 false);
 workingCopy.setAttribute(IAntLaunchConfigurationConstants.AT TR_ANT_PROPERTIES,
 new Properties()/*userProperties*/);
 workingCopy.setAttribute(IJavaLaunchConfigurationConstants.A TTR_DEFAULT_CLASSPATH,
 true);
 *and add the classpath that is taken from the project classpath
 /*get the classpath project*/
 ArrayList<String> array = new ArrayList();
 IClasspathEntry[] ices = JavaCore.create(aProject).getRawClasspath();
 /*I add only libraries coz I know that only libraries are needed*/
 for(IClasspathEntry ice : ices){
 IRuntimeClasspathEntry irce = null;
 int kind = ice.getEntryKind();
 if(kind == IClasspathEntry.CPE_LIBRARY && ice.getPath() != null){
 irce = JavaRuntime
 .newArchiveRuntimeClasspathEntry(ice.getPath().makeAbsolute( ));
 array.add(irce.getMemento());
 workingCopy.setAttribute(IJavaLaunchConfigurationConstants.A TTR_CLASSPATH,array);
 /*save the ILaunchConfiguration*/
 ILaunchConfiguration ilc = workingCopy.doSave();
 /*create associate ICommand*/
 desc = aProject.getDescription();
 command.setBuilderName("org.eclipse.ant.AntBuilderLaunchConfigurationType ");
 Map<String,String> map = command.getArguments();
 map.put("LaunchConfigHandle",
 "<project>/.externalToolBuilders/"+name
 +".launch");
 command.setArguments(map);
 command.setBuilderName(ilc.getName());
 command.setBuilding(IncrementalProjectBuilder.FULL_BUILD, true);
 command.setBuilding(IncrementalProjectBuilder.INCREMENTAL_BU ILD, true);
 nc[0] = command;
 aProject.setDescription(desc, null);
 With that, the builder is correctly create... Except for the classpath....
 I can edit it with the BuilderPropertyPage.
 The file .metadata/<generateName>.launch contains the good listEntry for
 the archive that I want to add in the classpath listAttribute. (The same
 as if I add it by the BuilderPropertyPage) but in the
 BuildeerPropertyPage, there is only the default classpath...
 So when I launch it, there are errors because it doesn't know the Class
 that are in the archive that I want to add to his classpath... so How can
 I add it?
 And why it doesn't take directly the classpath of the project which launch
 the ant build file??>
 thanks in advance
 A. Pupier wrote:
 > So I'm here :
 > AntLaunchShortcut antLS = new AntLaunchShortcut();
 > ILaunchConfiguration ilct = antLS
 > createDefaultLaunchConfiguration(iPathOfBuildFile, iProject);
 > ICommand commandToAdd;
 > commandToAdd = BuilderUtils.toBuildCommand(project, ilct, commandToAdd);
 > and I have this error :
 > java.lang.NullPointerException
 > 	at
 org.eclipse.ui.externaltools.internal.model.BuilderUtils.toB uildCommand(BuilderUtils.java:222)
 > 	at
 org.eclipse.ui.externaltools.internal.model.BuilderUtils.com mandFromLaunchConfig(BuilderUtils.java:134)
 > So I look in the source code :
 > the error is at this line (config is an ILaunchConfiguration):
 buffer.append('/').append(config.getFile().getFullPath().rem oveFirstSegments(1));
 > and in facts, config.getFile() return null and why?
 > When we look at the specification of getFile() from  ILaunchConfiguration
 > interface, we can read :
 > @return the file this launch configuration is stored
 > in, or <code>null</code> if this configuration is stored
 > locally with the workspace
 > ... it seems that my file is stored in the workspace...
 > But what is exactly this file?
 > I'm not sure, is it the buildfile?
 > So I don't know how to create the command correctly...
 > thanks for your help
 Current Time: Fri Oct 31 04:40:43 EDT 2025
 Powered by FUDForum . Page generated in 0.49948 seconds |
