Home » Eclipse Projects » Eclipse Platform » implement my own debug, only one step over by thread and frame
implement my own debug, only one step over by thread and frame [message #329815] |
Mon, 07 July 2008 01:19  |
hi all
I try to implement my own debug for a foreign language.
I implmemented the launcher, the stack frame, the target and the
debugelement (not value variable and breakpoint).
but the problem is when I launch the debug, the debug perspective come
and in the debug view I have the main trhead with a stack frame.
the button step over is clickable but if I click it, he do what he has
to do but the button come greys (I can't click it anymore). I have to
click on the thread and reclick on the stack frame. it 's like I have to
refresh it manualy.
I have no idea why but it's un-usable , if someone has a idea.
thanks.
a+++
PS: sorry for my english.
a
Re: implement my own debug, only one step over by thread and frame [message #330013 is a reply to message #330011] |
Sat, 12 July 2008 11:48   |
Julien,
I've never implemented a debugger so the best I can do, when no one else
seems to be providing help, is suggest something based on the problem
description (an explicit selection updates the buttons that otherwise
don't update). If that doesn't help, there's really nothing else I can
suggest. Hopefully someone else will suggest something...
julien wrote:
> Ed Merks a écrit :
>> Comments below.
>> julien wrote:
>>> hi all
>>> come and in the debug view I have the main trhead with a stack frame.
>>> has to do but the button come greys (I can't click it anymore). I
>>> have to click on the thread and reclick on the stack frame. it 's
>>> like I have to refresh it manualy.
>> It sounds like your stack frame view needs to produce a selection
>> event to select the top stack frame so that the buttons know the
>> value of the latest selection. Does the view have a setSelection
>> method you can call? Not that programatically setting the selection
>> of a widget doesn't fire the SWT event the same way as it does when
>> the user selects that same item in the widget, so likely you need to
>> select the right thing in the widget and ensure that the viewer-level
>> section event happens.
> heu... sorry I don"t understand everything.
> I based my debug on
> http://www.eclipse.org/articles/Article-Debugger/how-to.html
> and on code I found in google debug except for 1 differents, my debug
> is a executable and no a server-client debug.
> a++
>>> thanks.
>>> a+++
>>> a
Re: implement my own debug, only one step over by thread and frame [message #330015 is a reply to message #330013] |
Sat, 12 July 2008 12:16   |
Ed Merks a écrit :
> Julien,
thanks a lot.
> julien wrote:
>> Ed Merks a écrit :
>>> Comments below.
>>> julien wrote:
>>>> hi all
>> I based my debug on
>> a++
>>>> thanks.
>>>> a+++
>>>> a
Re: implement my own debug, only one step over by thread and frame [message #330087 is a reply to message #330011] |
Mon, 14 July 2008 11:10  |
All I can suggest is to make sure that you are you firing debug events
appropriately when you step, resume, hit a breakpoint, etc. If you are
stepping, I think you need to do something like:
- fire DebugEvent.RESUME event with
DebugEvent.STEP_INTO/DebugEvent.STEP_OVER detail
- perform the step in the physical debugger
- fire DebugEvent.SUSPEND event with DebugEvent.STEP_END detail
I think it is the SUSPEND event that will attempt to select your stack
frame and re-enable the step buttons. Of course, you need to make sure
that your debug elements (DebugTarget, StackFrame, etc.) also report their
state appropriately in terms of isSuspended, canStepInto, etc.
Mark.
On Sat, 12 Jul 2008 11:15:36 -0400, julien <elekis@gmail.com> wrote:
> Ed Merks a écrit :
>> Comments below.
>> julien wrote:
>>> hi all
>> It sounds like your stack frame view needs to produce a selection event
>> to select the top stack frame so that the buttons know the value of the
>> latest selection. Does the view have a setSelection method you can
>> call? Not that programatically setting the selection of a widget
>> doesn't fire the SWT event the same way as it does when the user
>> selects that same item in the widget, so likely you need to select the
>> right thing in the widget and ensure that the viewer-level section
>> event happens.
> I based my debug on
> and on code I found in google debug except for 1 differents, my debug is
> a++
Current Time: Mon Jul 21 23:59:06 EDT 2025
Powered by FUDForum. Page generated in 0.03610 seconds
