Home » Eclipse Projects » Eclipse Platform » debugger: return to current instruction pointer?
debugger: return to current instruction pointer? [message #329801] Fri, 04 July 2008 14:52 Go to next message
I miss a feature that I use a lot in the MS Visual Studio debugger.
Sometimes you scroll away from (what Eclipse calls) the current
instruction pointer to look for something. Maybe you switch to another
file.
Then after a while you want to continue debugging and want to return to
the current instruction pointer for that.
Visual Studio has a button in the debug toolbar where I can get back to
the current statement very easily.
I could not find anything like that in Eclipse. Am I too blind?
Re: debugger: return to current instruction pointer? [message #329802 is a reply to message #329801] Fri, 04 July 2008 14:55 Go to previous messageGo to next message
You can click on the top stack frame in the debug view.
> file. Then after a while you want to continue debugging and want to
> return to the current instruction pointer for that.
> to the current statement very easily. I could not find anything like
Re: debugger: return to current instruction pointer? [message #329803 is a reply to message #329802] Fri, 04 July 2008 15:56 Go to previous message
cool! thanks
Previous Topic:Re: build map files for ecf ganymede build
Next Topic:Annotation
Current Time: Sat Sep 06 14:21:42 EDT 2025
Powered by FUDForum. Page generated in 0.06670 seconds
