Home » Eclipse Projects » Eclipse Platform » Why two editor?
Why two editor? [message #329737] Wed, 02 July 2008 06:40
Originally posted by: fucillax.libero.it
I developed a little plugin for eclipse, for editing of a language of
programming...After the compiler, I need to signal the error by
annotation...
I try to do this, with :
public class BglEditor extends TextEditor implements
ISelectionChangedListener { // , IPropertyChangeListener
private ColorManager colorManager;
/*private EMonoCSharpFolder fFolder;*/
private ISourceViewer sourceViewer;
private IDocument document;
//private IdleTimer idleTimer;
private ProjectionSupport projectionSupport;
private BglConfiguration configuration;
/*protected EMonoOutlinePage page;*/
protected BglEditorExamineJob examinJob;
private BglBracketInserter bracketInserter;
protected BglBracketMatcher bracketMatcher = new BglBracketMatcher();
/*private TaskTracker taskTracker;*/
private ArrayList menuActionName;
private ArrayList menuActionSection;
private IWorkbenchWindow window;
private boolean compileWhenSave = false;
private String pathOfOutput = "";
* MODIFICHE 30 GIUGNO 2008
// error identifiers, images and colors
public static String ERROR_TYPE = "error.type";
public static Image ERROR_IMAGE = new Image(Display.getDefault(),
"C:\\Documents and
Settings\\Utente\\Desktop\\Tesi\\workspace\\bglEditor\\icons \\sample.gif ");;
public static final RGB ERROR_RGB = new RGB(255, 0, 0);
private AnnotationModel fAnnotationModel = new AnnotationModel();
* The property change listener gets notified if the preferences for this
plug-in change
private final IPropertyChangeListener prefChangeListener = new
IPropertyChangeListener() {
public void propertyChange(PropertyChangeEvent event) {
if (event.getProperty().equals(DefaultPrefsSetter.QUOTESCOMPLET ION) ||
event.getProperty().equals(DefaultPrefsSetter.BRACESCOMPLETI ONATENTER)
event.getProperty().equals(DefaultPrefsSetter.BRACESCOMPLETI ON) ||
event.getProperty().equals(DefaultPrefsSetter.BRACKETCOMPLET ION) ||
event.getProperty().equals(DefaultPrefsSetter.COMPILEWHENSAV E)) {
//|| event.getProperty().equals(DefaultPrefsSetter.PATHOUTPUT)) {
// update completions of bracket inserter
bracketInserter.setCloseBracketsEnabled(getPreferenceStore() .getBoolean(
DefaultPrefsSetter.BRACKETCOMPLETION));
bracketInserter.setCloseBracesEnabled(
getPreferenceStore().getBoolean(DefaultPrefsSetter.BRACESCOM PLETION)
getPreferenceStore().getBoolean(DefaultPrefsSetter.BRACESCOM PLETIONATENTER));
bracketInserter.setCloseStringsEnabled(getPreferenceStore(). getBoolean(
DefaultPrefsSetter.QUOTESCOMPLETION));
compileWhenSave =
BglPlugin.getDefault().getPreferenceStore().getBoolean(Defau ltPrefsSetter.COMPILEWHENSAVE);
//pathOfOutput =
BglPlugin.getDefault().getPreferenceStore().getString(Defaul tPrefsSetter.PATHOUTPUT);
// get the BglAutoIndentStrategy via our source viewer configuration
and
// call its setBracesCompletion() method
((BglAutoIndentStrategy)configuration.getAutoEditStrategies(
sourceViewer,IDocument.DEFAULT_CONTENT_TYPE)[0]).setBracesCo mpletion(
BglPlugin.getDefault().getPreferenceStore().getBoolean(Defau ltPrefsSetter.BRACESCOMPLETIONATENTER)
BglPlugin.getDefault().getPreferenceStore().getBoolean(Defau ltPrefsSetter.BRACESCOMPLETION)
private Composite compositeParent;
* Constructor
public BglEditor() {
super();
examinJob = new BglEditorExamineJob(this,"ExamineEditor");
colorManager = new ColorManager();
configuration = new BglConfiguration(colorManager,this);
setSourceViewerConfiguration(configuration);
setDocumentProvider(new BglDocumentProvider());
IPreferenceStore generalTextStore = EditorsUI.getPreferenceStore();
ChainedPreferenceStore preferenceStore = new ChainedPreferenceStore(new
IPreferenceStore[] {BglPlugin.getDefault().getPreferenceStore(),
generalTextStore});
setPreferenceStore(preferenceStore);
compileWhenSave =
//pathOfOutput =
* Is called on changes in the preferences. Triggers update of editor
colors
* on changes in syntax coloring.
* @param event The event containing the preference changes
protected boolean affectsTextPresentation(PropertyChangeEvent event)
if (event.getProperty().equals(DefaultPrefsSetter.STRINGCOLOR) ||
event.getProperty().equals(DefaultPrefsSetter.STRINGBOLD) ||
event.getProperty().equals(DefaultPrefsSetter.COMMENTBOLD) ||
event.getProperty().equals(DefaultPrefsSetter.COMMENTCOLOR) ||
event.getProperty().equals(DefaultPrefsSetter.CALCBOLD) ||
event.getProperty().equals(DefaultPrefsSetter.CALCCOLOR) ||
event.getProperty().equals(DefaultPrefsSetter.KEYWORDBOLD) ||
event.getProperty().equals(DefaultPrefsSetter.KEYWORDCOLOR)) {
// this will update the tokens of the scanners - must be done before
configuration.updateScannerColors();
// this will kick the scanner
return true;
return false;
* @see org.eclipse.ui.editors.text.TextEditor#dispose()
public void dispose() {
if (colorManager != null) colorManager.dispose();
if (examinJob != null) examinJob.cancel();
//actions
/*String[] actionIds = DefaultBglSourceDelegate.getEditorActions();
for (int i = 0; i < actionIds.length; i++) {
IAction action = getAction(actionIds[i]);
if (action instanceof DefaultBglSourceAction)
((DefaultBglSourceAction) action).dispose();
if (sourceViewer instanceof ITextViewerExtension)
((ITextViewerExtension)
sourceViewer).removeVerifyKeyListener(bracketInserter);
// remove property listener of preference store
getPreferenceStore().removePropertyChangeListener(prefChange Listener);
super.dispose();
* @see
org.eclipse.ui.texteditor.AbstractTextEditor#rulerContextMen uAboutToShow(IMenuManager)
public void rulerContextMenuAboutToShow(IMenuManager menu) {
super.rulerContextMenuAboutToShow(menu);
// We dont use it quite now, but may be we add some ations to the ruler
menu some time
// ViewerActionBuilder builder = new ViewerActionBuilder();
// builder.readViewerContributions("#CSharpRulerContext",
// getSelectionProvider(), this);
// builder.contribute(menu, null, true);
* Returns the ExamineJob that is responsible for various jobs (scanning,
parsing, ...)
* @return The CSharpEditorExamineJob instance of this editor
public BglEditorExamineJob getExamineJob(){
return examinJob;
* @see org.eclipse.ui.texteditor.AbstractTextEditor#createActions()
protected void createActions() {
super.createActions();
IDocumentProvider provider = getDocumentProvider();
document = provider.getDocument(getEditorInput());
sourceViewer = getSourceViewer();
sourceViewer.setDocument(document);
// create BracketInserter; do it here because we need the sourceViewer
bracketInserter = new BglBracketInserter(this, sourceViewer);
bracketInserter.setCloseBracketsEnabled(getPreferenceStore() .getBoolean(DefaultPrefsSetter.BRACKETCOMPLETION));
bracketInserter.setCloseBracesEnabled(getPreferenceStore().g etBoolean(DefaultPrefsSetter.BRACESCOMPLETION)
!getPreferenceStore().getBoolean(DefaultPrefsSetter.BRACESCO MPLETIONATENTER)
bracketInserter.setCloseStringsEnabled(getPreferenceStore(). getBoolean(DefaultPrefsSetter.QUOTESCOMPLETION));
* @see
org.eclipse.ui.texteditor.AbstractTextEditor#editorContextMe nuAboutToShow(IMenuManager)
public void editorContextMenuAboutToShow(IMenuManager menu) {
super.editorContextMenuAboutToShow(menu);
Separator s = new Separator();
menu.appendToGroup("additions", s);
if (menuActionName != null && menuActionSection != null) {
for (int i = 0; i < menuActionName.size(); i++) {
addAction(menu, (String) menuActionSection.get(i),
(String) menuActionName.get(i));
* @see org.eclipse.ui.editors.text.TextEditor#getAdapter(Class)
public Object getAdapter(Class adapter) {
if (ProjectionAnnotationModel.class.equals(adapter)) {
if (projectionSupport != null) {
// forward request
Object result = projectionSupport.getAdapter(getSourceViewer(),
adapter);
if (result != null) {
return result;
// Adapter for the Outline view
/*if (adapter.equals(IContentOutlinePage.class)) {
if (page == null)
page = new EMonoOutlinePage(this, getSourceViewer());
//this.registerIdleListener(page);
//page.addSelectionChangedListener(this);
return page;
return super.getAdapter(adapter);
* @see
org.eclipse.ui.texteditor.AbstractTextEditor#createPartContr ol(Composite)
public void createPartControl(Composite parent) {
super.createPartControl(parent);
/* Tolto il 2 luglio 2008
ProjectionViewer viewer = (ProjectionViewer) getSourceViewer();
projectionSupport = new ProjectionSupport(viewer,
getAnnotationAccess(), getSharedColors());
projectionSupport
.addSummarizableAnnotationType("org.eclipse.ui.workbench.texteditor.error ");
projectionSupport
.addSummarizableAnnotationType("org.eclipse.ui.workbench.texteditor.warning ");
projectionSupport.install();
viewer.doOperation(ProjectionViewer.TOGGLE);
* fin qui
// Verify key listener for Bracket Inserter
if (sourceViewer instanceof ITextViewerExtension) {
sourceViewer).prependVerifyKeyListener(bracketInserter);
// listen for property changes
getPreferenceStore().addPropertyChangeListener(prefChangeLis tener);
setProva();
* @see
org.eclipse.ui.texteditor.AbstractTextEditor#createSourceVie wer(Composite,
IVerticalRuler, int)
protected final ISourceViewer createSourceViewer(Composite parent,
IVerticalRuler ruler, int styles) {
fOverviewRuler = createOverviewRuler(getSharedColors());
ISourceViewer sourceViewer = new BglSourceViewer(parent, ruler,
fOverviewRuler, isOverviewRulerVisible(), styles);
getSourceViewerDecorationSupport(sourceViewer);
compositeParent = parent;
return sourceViewer;
protected void
configureSourceViewerDecorationSupport(SourceViewerDecoratio nSupport
support) {
support.setCharacterPairMatcher(bracketMatcher);
support.setMatchingCharacterPainterPreferenceKeys(DefaultPre fsSetter.BRACKETMATCHING,
DefaultPrefsSetter.BRACKETMATCHINGCOLOR);
super.configureSourceViewerDecorationSupport(support);
protected void editorSaved(){
super.editorSaved();
IResource resource = (IResource)
getEditorInput().getAdapter(IResource.class);
/*if (resource != null) {
taskTracker.checkForTasks(document, resource);
******* Modifiche ***********
if (compileWhenSave) {
MessageConsole console = findConsole("BusinessGame compiler");
MessageConsoleStream out = console.newMessageStream();
String s = eseguiExe();
if (s.equals("Editor nullo")) {
MessageDialog.openInformation(
window.getShell(),
"BGL Plug-in",
"Nessun modello correntemente aperto!!!");
else if (s.equals("Estensione non corretta")) {
window.getShell(),
"BGL Plug-in",
"Il file che si desidera compilare non e' un \"BGL model\"!!!");
else {
out.println(s);
prova2();
* Returns the source viewer
* @return the source viewer
public ISourceViewer getViewer(){
public void selectionChanged(SelectionChangedEvent event) {
// Nothing to do there in the moment
private MessageConsole findConsole(String name)
ConsolePlugin plugin = ConsolePlugin.getDefault();
IConsoleManager conMan = plugin.getConsoleManager();
MessageConsole console = new MessageConsole(name, null);
console.activate();
conMan.addConsoles(new IConsole[]{console});
return console;
public String eseguiExe()
String s = "";
IWorkbench wb = PlatformUI.getWorkbench();
IWorkbenchWindow win = wb.getActiveWorkbenchWindow();
IWorkbenchPage page = win.getActivePage();
IEditorPart editor = page.getActiveEditor();
if (editor == null) {
return "Editor nullo";
else {
IFile original = ((FileEditorInput)editor.getEditorInput()).getFile();
if (!(original.getFileExtension().equals("bgl"))) return "Estensione
non corretta";
s += original.getLocation().toString();
try
BGCompileOutput out = BGCompiler.compile(s);
s = out.getOutput();
if (out.success()) {
// Crea il modello
BGModel modello = out.getBGModel();
// String nomeProgetto = original.getProject().getName();
if (pathOfOutput.equals("")) {
IProject progetto = original.getProject();
String percorsoProgetto = progetto.getLocation().toString();
int pos = original.getName().lastIndexOf(".");
String nome = original.getName().substring(0, pos);
File fileOutput = new File(percorsoProgetto+"/bgm_output");
fileOutput.mkdir();
String fileName = percorsoProgetto + "/bgm_output/"+nome+".bgm";
FileOutputStream f = new FileOutputStream(fileName);
ObjectOutputStream oos = new ObjectOutputStream(f);
oos.writeObject(modello);
oos.flush();
oos.close();
else {
String fileName = pathOfOutput + "\\"+nome+".bgm";
oos.flush();
oos.close();
catch(Throwable e)
e.printStackTrace();
s = "Eccezione nella compilazione";
return s;
class AnnotationConfiguration implements IInformationControlCreator {
public IInformationControl createInformationControl(Shell shell) {
return new DefaultInformationControl(shell);
class ColorCache implements ISharedTextColors {
public Color getColor(RGB rgb) {
return new Color(Display.getDefault(), rgb);
// santa's little helper
class AnnotationMarkerAccess implements IAnnotationAccess,
IAnnotationAccessExtension {
public Object getType(Annotation annotation) {
return annotation.getType();
public boolean isMultiLine(Annotation annotation) {
return true;
public boolean isTemporary(Annotation annotation) {
return !annotation.isPersistent();
public String getTypeLabel(Annotation annotation) {
if (annotation instanceof ErrorAnnotation)
return "Errors";
return null;
public int getLayer(Annotation annotation) {
return ((ErrorAnnotation)annotation).getLayer();
return 0;
public void paint(Annotation annotation, GC gc, Canvas canvas,
Rectangle bounds) {
ImageUtilities.drawImage(((ErrorAnnotation)annotation).getIm age(), gc,
canvas, bounds, SWT.CENTER, SWT.TOP);
public boolean isPaintable(Annotation annotation) {
return ((ErrorAnnotation)annotation).getImage() != null;
return false;
public boolean isSubtype(Object annotationType, Object
potentialSupertype) {
if (annotationType.equals(potentialSupertype))
return true;
return false;
public Object[] getSupertypes(Object annotationType) {
return new Object[0];
// source viewer configuration
class CodeViewerConfiguration extends SourceViewerConfiguration {
private ColorCache manager;
public CodeViewerConfiguration(ColorCache manager) {
this.manager = manager;
public IPresentationReconciler
getPresentationReconciler(ISourceViewer sourceViewer) {
PresentationReconciler reconciler = new
PresentationReconciler();
return reconciler;
public IAnnotationHover getAnnotationHover(ISourceViewer
sourceViewer) {
return new AnnotationHover();
// annotation hover manager
class AnnotationHover implements IAnnotationHover, ITextHover {
public String getHoverInfo(ISourceViewer sourceViewer, int
lineNumber) {
Iterator ite = fAnnotationModel.getAnnotationIterator();
ArrayList<String> all = new ArrayList<String>();
while (ite.hasNext()) {
Annotation a = (Annotation) ite.next();
if (a instanceof ErrorAnnotation) {
all.add(((ErrorAnnotation)a).getText());
StringBuffer total = new StringBuffer();
for (int x = 0; x < all.size(); x++) {
String str = (String) all.get(x);
total.append(" " + str + (x == (all.size()-1) ? "" :
"\n"));
return total.toString();
public String getHoverInfo(ITextViewer textViewer, IRegion
hoverRegion) {
return null;
public IRegion getHoverRegion(ITextViewer textViewer, int offset) {
return null;
// one error annotation
class ErrorAnnotation extends Annotation {
private IMarker marker;
private String text;
private int line;
private Position position;
public ErrorAnnotation(IMarker marker) {
this.marker = marker;
public ErrorAnnotation(int line, String text) {
super(ERROR_TYPE, true, null);
this.marker = null;
this.line = line;
this.text = text;
public IMarker getMarker() {
return marker;
public int getLine() {
return line;
public String getText() {
return text;
public Image getImage() {
return ERROR_IMAGE;
public int getLayer() {
return 3;
public String getType() {
return ERROR_TYPE;
public Position getPosition() {
return position;
public void setPosition(Position position) {
this.position = position;
private void setProva() {
if (document == null) {
System.out.println("document nullo");
if (compositeParent == null) {
System.out.println("parent nullo");
return;
int styles = SWT.V_SCROLL | SWT.H_SCROLL | SWT.MULTI | SWT.BORDER
| SWT.FULL_SELECTION;
fAnnotationAccess = new AnnotationMarkerAccess();
ColorCache cc = new ColorCache();
CompositeRuler fCompositeRuler = new CompositeRuler();
fOverviewRuler = new OverviewRuler(fAnnotationAccess, 12,
getSharedColors());
AnnotationRulerColumn annotationRuler = new
AnnotationRulerColumn(fAnnotationModel, 16, fAnnotationAccess);
fCompositeRuler.setModel(fAnnotationModel);
fOverviewRuler.setModel(fAnnotationModel);
fCompositeRuler.addDecorator(0, annotationRuler);
annotationRuler.addAnnotationType(ERROR_TYPE);
fOverviewRuler.addAnnotationType(ERROR_TYPE);
fOverviewRuler.addHeaderAnnotationType(ERROR_TYPE);
fOverviewRuler.setAnnotationTypeLayer(ERROR_TYPE, 3);
fOverviewRuler.setAnnotationTypeColor(ERROR_TYPE, new
Color(Display.getDefault(), ERROR_RGB));
sourceViewer = new BglSourceViewer(compositeParent,
fCompositeRuler, fOverviewRuler, isOverviewRulerVisible(), styles);
sourceViewer.setDocument(document, fAnnotationModel);
AnnotationBarHoverManager fAnnotationHoverManager = new
AnnotationBarHoverManager(fCompositeRuler, sourceViewer, new
AnnotationHover(), new AnnotationConfiguration());
fAnnotationHoverManager.install(annotationRuler.getControl() );
AnnotationPainter ap = new AnnotationPainter(sourceViewer,
fAnnotationAccess);
ap.addAnnotationType(ERROR_TYPE);
ap.setAnnotationTypeColor(ERROR_TYPE, new
((BglSourceViewer)sourceViewer).addPainter(ap);
sourceViewer.configure(new CodeViewerConfiguration(cc));
private void prova2() {
ErrorAnnotation errorAnnotation = new ErrorAnnotation(1,
"Error!!!");
fAnnotationModel.addAnnotation(errorAnnotation, new Position(5,
12));
the method "setProva()" call in createPartControl(Composite parent), open
two textEditor in a window...
Can anyone help me please???
Previous Topic:error while exporting plugin
Next Topic:Source lookup in a custom debugger
Current Time: Tue Nov 04 03:43:06 EST 2025
Powered by FUDForum. Page generated in 0.04073 seconds
