Home » Eclipse Projects » Eclipse Platform » How do I disable the File menu item - Save?
How do I disable the File menu item - Save? [message #329719] Tue, 01 July 2008 17:12 Go to next message
I implemented an object editor that performs the open-save-close
operation on a specific file extension. However, I allow files with a
different extension to be opened (Open With/Other../MyEditor) and the
file contents are converted to the file format of the object file.
When I open a file with the non-default extension the file is marked
dirty to force a "SaveAs" operation. However, the "Save" operation is
also enabled. This should be disabled as the file is not the default
file type extension. So how do I disable the "Save" operation in the
File menu?
Also, when I do perform a "SaveAs" operation the filename does not
change to the new filename. Do I have to do this programmatically? If
so, what is the preferred method?
Ray
Re: How do I disable the File menu item - Save? [message #329721 is a reply to message #329719] Tue, 01 July 2008 18:15 Go to previous messageGo to next message
It looks like the "Save" and "Save As" operations cannot be disabled (
always enabled).
Is this correct?
If so, then I must detect in the "Save" operation that the filename is
incorrect and divert it to the "Save As" operation. Correct?
Do I need to use the IReuseableEditor part for this?
Does the IReuseableEditor part fix the filename issue on the "Save As"
command?
Ray
> File menu?
> Ray
Re: How do I disable the File menu item - Save? [message #329748 is a reply to message #329721] Wed, 02 July 2008 10:48 Go to previous message
> always enabled).
> Is this correct?
You should be able to do this in your EditorPart's doSave(*) method ...
maybe examining your IEditorInput and diverting to your doSaveAs(*) method.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:efs usage in team/cvs plugin
Next Topic:What happened to the feature concept in Ganymede
Current Time: Sat Sep 06 18:11:42 EDT 2025
Powered by FUDForum. Page generated in 0.03003 seconds
