Home » Eclipse Projects » Eclipse Platform » Source not found only while debugging
Source not found only while debugging [message #329654] Mon, 30 June 2008 17:55
Originally posted by: virtue.012.net.il
guys,
Eclipse 3.3.2 / debug perspective
while starting the debugger I get the following message:
"Class file editor
Source not found
The source attachment does not contain the source for the ClassLoader.class
You can change the source attachment by clicking Change Attached Source
below:"
running is OK with no warnings,meaning that code and runtime are OK, looks
like only the debugger is missing some source file, I tried to uncheck
"suspend execution on uncaught exceptions" at preferences>java>debug but
it wont help
how can I eliminate the warning or make the debugger ignore it?
thanks
Previous Topic:Running Selected Ant target
Next Topic:[Eclipse 3.4] Using multiple configurations with a shared installation
Current Time: Wed Oct 29 03:34:28 EDT 2025
Powered by FUDForum. Page generated in 0.22860 seconds
