3.4 .link files under OS-X 10.5.3 [message #329610] |
Mon, 30 June 2008 02:55  |
Originally posted by: post.peter-jacobsen.de
Did anybody get .link files to work under OS-X 10.5.3? I tried .link
files in the "dropins" and "links" folder but Eclipse does not recognize
the plugins. Creating a symbolic link in the dropins folder (using the
path=/blah... section from the link file) to the plugin directory works
- so the path is correct, but I'd rather use .link files. Any ideas?
Peter
Re: 3.4 .link files under OS-X 10.5.3 [message #329707 is a reply to message #329706] |
Tue, 01 July 2008 10:15  |
Originally posted by: ekkehard.gentz-software.de
perhaps thats the only difference - I'm working as administrator
ekke
Peter Jacobsen schrieb:
> Hi ekke - yes, either copying or creating a symbolic link works. I set
> the dropins folder to 0777 because I do not work as administrator on
> OS-X. Really strange.
> Peter
> ekke schrieb:
>> yes - this is correct and exactly the same structure as mine
>> if you copy
>> jseclipse/eclipse/plugins + / features
>> directly into your dropins folder - then it works ?
>> ekke
>>> Hmmm - for me in the dropins folder only installed plugins or
>>> symbolic links to a plugin folder structure work.
>>> For example my jseclipse.link looks like this:
>>> path=/Users/peter/eclipse-plugins/jseclipse
>>> Directory structure:
>>> /Users/peter/eclipse-plugins/jseclipse/eclipse/plugins
>>> /features
>>> I assume this is correct?
>>> Peter
>>> ekke schrieb:
>>>> for me it works both:
>>>> dropins/foo/eclipse/plugins
>>>> dropins/foo.link
>>>> the .link file contains
>>>> path=/your_path
>>>> osx 10.5.3
>>>> ekke
>>>>> Eric,
>>>>> the documentation says it should work - the "dropins" folder
>>>>> supports plugin stuctures direcly and .link files, the "links"
>>>>> folder is kept for backwards compatibility.
>>>>> Did anybody get it to work under OS-X 10.5.3?
>>>>> Thanks,
>>>>> Peter
>>>>> Eric Rizzo schrieb:
>>>>>>> .link files in the "dropins" and "links" folder but Eclipse does
>>>>>>> not recognize the plugins. Creating a symbolic link in the
>>>>>>> dropins folder (using the path=/blah... section from the link
>>>>>>> file) to the plugin directory works - so the path is correct, but
>>>>>> I'm not sure .link files are still supported with p2. Read up on
>>>>>> it here: http://wiki.eclipse.org/Equinox_p2_Getting_Started
>>>>>> Hope this helps,
>>>>>> Eric
FUDForum. Page generated in 0.28604 seconds
