Home » Eclipse Projects » Eclipse Platform » [Eclipse 3.4] Using multiple configurations with a shared installation
[Eclipse 3.4] Using multiple configurations with a shared installation [message #329532] Fri, 27 June 2008 06:43 Go to next message
Up to Eclipse 3.4 I've been using to start Eclipse the following way:
eclipse -configuration <cfg_path> -data <wsp_path>
I'm using number of configuration areas setup with different
extension location sets. I eventually run:
eclipse -initialize
of the main shared configuration to improve startup time (as
suggested in the documentation [1]) but I haven't really seen much
improvement, if at all.
Now with the Eclipse 3.4 release I observe I can no longer use this
approach. If I specify a -configuration different from the shared
one I get a workbench with some minimal set of features ("Resource",
"Team Synchronizing" and "Debug" - no "Java").
FWIW, I've noticed an additional "p2" directory gets created in the
same parent directory of the configuration directory location I've
specified.
Is it possible (and how) to use multiple configurations with a
shared installation of Eclipse 3.4?
[1]
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
Stanimir
Re: [Eclipse 3.4] Using multiple configurations with a shared installation [message #329581 is a reply to message #329532] Sun, 29 June 2008 08:51 Go to previous messageGo to next message
Fri, 27 Jun 2008 13:43:07 +0300, /Stanimir Stamenkov/:
> approach. If I specify a -configuration different from the shared one I
> get a workbench with some minimal set of features ("Resource", "Team
I don't know what happens but seems it works in some cases, in some
cases it doesn't. The following case always makes Eclipse 3.4 start
the way I've described above:
1. Extract Eclipse to "I:\ecl\eclipse";
2. Change the current directory to "I:\ecl\eclipse" and start it using:
eclipse -console -configuration I:\ecl\cfg -data I:\ecl\wsp
I don't see any error reported. If I change the command line to:
eclipse -console -configuration I:\tmp\cfg -data I:\tmp\wsp
It works just fine.
Stanimir
Re: [Eclipse 3.4] Using multiple configurations with a shared installation [message #329583 is a reply to message #329581] Sun, 29 June 2008 09:03 Go to previous messageGo to next message
Sun, 29 Jun 2008 15:51:23 +0300, /Stanimir Stamenkov/:
>> I get a workbench with some minimal set of features ("Resource", "Team
> cases it doesn't. The following case always makes Eclipse 3.4 start the
> It works just fine.
FWIW, I'm using the Java EE package (eclipse-jee-ganymede-win32.zip).
Stanimir
Re: [Eclipse 3.4] Using multiple configurations with a shared installation [message #329670 is a reply to message #329583] Tue, 01 July 2008 04:42 Go to previous message
I asked a similar question, at
http://dev.eclipse.org/newslists/news.eclipse.platform/msg73 785.html
- and there were no satisfying answer.
Roman
Previous Topic:Source not found only while debugging
Next Topic:Please Help !!! Regarding inserting text in an editor through a view.
Current Time: Sat Nov 08 00:25:34 EST 2025
Powered by FUDForum. Page generated in 0.03607 seconds
