Home » Eclipse Projects » Eclipse Platform » Empty problems view (3.4)
Empty problems view (3.4) [message #329508] Thu, 26 June 2008 09:20 Go to next message
Originally posted by: b_apolci.libero.it
I just installed Ganymede and actually the Problems View show an empty
list even if I have plenty of warnings and some compilation error.
I looked at the Configure Content dialog, but all seems ok (I also tried
to change some option).
The error log is clean.
I downloaded the Eclipse Classic distribution and then added some
feature from the Ganymede update site (Mylin, SVN integration, WTP).
I also added Eclemma (plugin for junit test coverate).
If I start with a new workspace the problems view works fine (it show
the errors), but if I open my usual workspace (created with 3.3.1
version of eclipse) the problems view is always empty.
Has anyone some suggestion?
Is this a known problem?
Should I open a bug report?
Andrea
Re: Empty problems view (3.4) [message #329509 is a reply to message #329508] Thu, 26 June 2008 09:24 Go to previous messageGo to next message
One more thing: I already looked in the bugzilla but didn't find any bug
that seems related to this problem.
Andrea
Re: Empty problems view (3.4) - SOLVED [message #329510 is a reply to message #329508] Thu, 26 June 2008 09:35 Go to previous messageGo to next message
> list even if I have plenty of warnings and some compilation error...
Obviously it was my fault, the Error and Warning checks in the Configure
Content dialog weren't selected.
Andrea
Re: Empty problems view (3.4) - SOLVED [message #329596 is a reply to message #329510] Sun, 29 June 2008 13:41 Go to previous message
"Andrea Polci" <b_apolci@libero.it> wrote in message
news:g405vk$vrb$1@build.eclipse.org...
I think I have seen cases where workspaces created in earlier versions of
Eclipse ended up with unhelpful Problems configurations when loaded into
Ganymede. I've never been able to describe the necessary conditions to make
it happen, though :-(
Previous Topic:Annotation
Next Topic:3.4, Cannot launch the Update UI
Current Time: Mon Sep 01 01:37:47 EDT 2025
Powered by FUDForum. Page generated in 0.03856 seconds
