Home » Eclipse Projects » Eclipse Platform » Can't update TableViewer when Button is pressed
Can't update TableViewer when Button is pressed [message #329488] Thu, 26 June 2008 00:51 Go to next message
Originally posted by: hardy.oei.gmail.com
dear all,
I have a Button class that add a AddUserListener class so that whenever
a user clicked on it, it will reload the database data into the
TableViewer model and refresh the TableViewer. But then, I'm unable to
do so. Something is wrong and I don't know why.
This is a snippet of my code:
public class AddUserListener implements SelectionListener{
public void widgetSelected(SelectionEvent e) {
if(passwordForm.getText().equals(confirmPasswordForm.getText ())){
DBConnection.openConnection();
DBConnection.update("Insert into USER Values('"
+ userNameForm.getText()+"','"
+ nameForm.getText()+"','"
+ passwordForm.getText()+"','"
+ emailForm.getText()+"','"
+ new Date(Calendar.getInstance().getTime().getTime())
DBConnection.closeConnection();
//When this is called the table
//should update itself using
//refresh();
userTableViewer.notifyViewer();
//the application never execute these lines below
String message = "User with "
+" Success"; MessageDialog.openInformation(
((Button)e.getSource()).getShell()
, "Add User Success", message);
userNameForm.setText("");
nameForm.setText("");
passwordForm.setText("");
confirmPasswordForm.setText("");
emailForm.setText("");
This is the content of userTableViewer.notifyViewer() in the
UserTableViewer class :
public void notifyViewer() {
Display display = PlatformUI.getWorkbench().getDisplay();
display.asyncExec(new Runnable(){
public void run(){
ResultSet rs;
final CachedRowSet crs;
try {
rs = DBConnection.query("SELECT * FROM USER");
crs = new CachedRowSetImpl();
crs.populate(rs);
userTableViewer.refresh(crs);
} catch (SQLException ex) {
ex.printStackTrace();
I try to debug my program using eclipse, butwhenever the debug cursor
reach userTableViewer.notifyViewer(); line, it always goes to the
EventTable class. It seems that the application never execute the
userTableViewer.notifyViewer() line.
public void sendEvent (Event event) {
if (types == null) return;
level += level >= 0 ? 1 : -1;
try {
for (int i=0; i<types.length; i++) {
if (event.type == SWT.None) return;
if (types [i] == event.type) {
Listener listener = listeners [i];
if (listener != null) listener.handleEvent (event);
//The debug cursor start at this line.
} finally {
boolean compact = level < 0;
level -= level >= 0 ? 1 : -1;
if (compact && level == 0) {
int index = 0;
if (types [i] != 0) {
types [index] = types [i];
listeners [index] = listeners [i];
index++;
for (int i=index; i<types.length; i++) {
types [i] = 0;
listeners [i] = null;
That's my problem. I would be very grateful if someone have a look at my
problem and give a solution on it.
Hardy
Re: Can't update TableViewer when Button is pressed [message #329490 is a reply to message #329488] Thu, 26 June 2008 02:49 Go to previous messageGo to next message
> public void run(){
> ResultSet rs;
> try {
> crs.populate(rs);
This is the offending code. You should call
userTableViewer.setInput(crs). Your code simply tells the viewer to
rebuild the structure consulting the current content provider with the
current input (which is your original one).
The reason the debugger goes not straight into your run() code is that
you are adding an event to the event queue (Display#asyncExec).
By the way your code is wrong IMHO because you are doing whole blocking
operation inside the Runnable#run-method and this means the UI freezes
until your DB-operation finished.
The code is better written like this:
ResultSet rs;
try {
crs.populate(rs);
display.asyncExec( new Runnable() {
public void run() {
userTableViewer.setInput(crs);
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Can't update TableViewer when Button is pressed [message #329492 is a reply to message #329490] Thu, 26 June 2008 03:28 Go to previous messageGo to next message
>> public void run(){
>> ResultSet rs;
>> try {
>> crs.populate(rs);
> ResultSet rs;
> try {
> crs.populate(rs);
> public void run() {
> Tom
Thank you for the reply. I have configured the notifyViewer just as the
way you suggest, but still the table won't refresh itself in the GUI. I
even try to call userTableViewer.refresh() after the
userTableViewer.setInput(crs). But it doesn't work also. One thing that
I don't understand is:
If I put the userTableViewer.notifyViewer() before calling the Message
Dialog. When I run the application, the Message Dialog never shows up,
as if the application never execute anything below the
userTableViewer.notifyViewer(). Why is that happening?
String message = "User with "+ userNameForm.getText()+" added
successfully";
MessageDialog.openInformation(((Button)e.getSource()).getShe ll(), "Add
Hardy
Re: Can't update TableViewer when Button is pressed [message #329493 is a reply to message #329492] Thu, 26 June 2008 03:32 Go to previous messageGo to next message
Is this an RCP/Platform Plugin? Then run with -consoleLog and see if an
exception is logged to the console. This definately looks like a
Runtime-Exception happing some where in the notifyViewer-method.
Tom
>>> public void run(){
>>> ResultSet rs;
>>> try {
>>> crs.populate(rs);
>> blocking operation inside the Runnable#run-method and this means the
>> UI freezes until your DB-operation finished.
>> ResultSet rs;
>> try {
>> crs.populate(rs);
>> public void run() {
>> Tom
> successfully";
> Hardy
Re: Can't update TableViewer when Button is pressed [message #329496 is a reply to message #329493] Thu, 26 June 2008 03:44 Go to previous messageGo to next message
> Tom
It seems this line below cause the error:
But I don't know what's wrong with it. Any ideas?
The following is the error log:
!SESSION 2008-06-26 15:40:56.406
eclipse.buildId=unknown
java.version=1.6.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=in_ID
Framework arguments: -product com.blodstone.server.rcp.product
Command-line arguments: -product com.blodstone.server.rcp.product -data
C:\Documents and
Settings\Supervisor\workspace/../runtime-com.blodstone.serve r.rcp.application
-dev file:C:/Documents and
Settings/Supervisor/workspace/.metadata/.plugins/org.eclipse .pde.core/com.blodstone.server.rcp.application/dev.propertie s
-os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2008-06-26 15:41:08.031
!MESSAGE Unhandled event loop exception
!STACK 0
com.blodstone.server.rcp.views.listeners.AddUserListener.wid getSelected(AddUserListener.java:82)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at com.blodstone.server.rcp.Application.start(Application.java: 20)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Hardy
Re: Can't update TableViewer when Button is pressed [message #329497 is a reply to message #329496] Thu, 26 June 2008 03:49 Go to previous messageGo to next message
What's the code at AddUserListener.java:82?
Tom
Hardy schrieb:
>> an exception is logged to the console. This definately looks like a
>> Tom
> C:\Documents and
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Hardy
Re: Can't update TableViewer when Button is pressed [message #329498 is a reply to message #329497] Thu, 26 June 2008 04:30 Go to previous messageGo to next message
> Tom
I've rewrite UserTableViewer class so that I can know which code is
really giving me the error.
Here is the class snippet:
ResultSet rs;
try {
crs.populate(rs);
public void run(){
userTableViewer.refresh(false);
}catch (SQLException ex) {
String message = "User with "+ userNameForm.getText()+" adding success";
).getShell(), "Add User Success", message); userNameForm.setText("");
It give me this error
(com.blodstone.server.rcp.views.listeners.AddUserListener.wi dgetSelected(AddUserListener.java:94)is
"Add User Success", message); )
!SESSION 2008-06-26 16:16:23.078
C:\Documents and
!ENTRY org.eclipse.ui 4 0 2008-06-26 16:16:34.437
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.jface.dialogs.MessageDialog.openInformation(Mess ageDialog.java:346)
com.blodstone.server.rcp.views.listeners.AddUserListener.wid getSelected(AddUserListener.java:94)
Caused by: java.lang.NullPointerException
com.blodstone.server.rcp.views.listeners.AddUserListener$1.r un(AddUserListener.java:85)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 32 more
Hardy
Re: Can't update TableViewer when Button is pressed [message #329500 is a reply to message #329498] Thu, 26 June 2008 05:09 Go to previous messageGo to next message
My guess is that:
e.getSource() is null. You should use e.widget instead.
Tom
Hardy schrieb:
>> Tom
> ResultSet rs;
> try {
> crs.populate(rs);
> public void run(){
> success";
> C:\Documents and
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
> Hardy
Re: Can't update TableViewer when Button is pressed [message #329502 is a reply to message #329500] Thu, 26 June 2008 05:26 Go to previous messageGo to next message
Tom Schindl wrote:
> My guess is that:
> Tom
> Hardy schrieb:
I changed to
MessageDialog.openInformation(((Button)e.widget).getShell(), "Add User
Success", message);
I still give me the same error log. And the table still won't refresh
itself also.
regards,
Hardy
Re: Can't update TableViewer when Button is pressed [message #329503 is a reply to message #329502] Thu, 26 June 2008 05:52 Go to previous messageGo to next message
Hardy please use a Debugger and step through the code and see which
variable is null in your case. You could also add a NullPointerException
rule this way you can run your code with any break points and can jump
right to the line the NPE occurred and inspect the variables.
Could it be that "e" is null?
Tom
Hardy schrieb:
> Tom Schindl wrote:
>> My guess is that:
>> Tom
>> Hardy schrieb:
> I changed to
> Success", message);
> itself also.
> regards,
> Hardy
Re: Can't update TableViewer when Button is pressed [message #329505 is a reply to message #329503] Thu, 26 June 2008 06:54 Go to previous messageGo to next message
> Tom
> Hardy schrieb:
>> Tom Schindl wrote:
>>> My guess is that:
>>> Tom
>>> Hardy schrieb:
>> I changed to
>> Success", message);
>> itself also.
>> regards,
>> Hardy
I think the problem lies within setinput(crs); because whenever I reach
that line using my debug. When I reach that line, it always goes to the
infinite loop within the workbench class. It keeps executing these lines:
private void runEventLoop(Window.IExceptionHandler handler, Display
display) {
runEventLoop = true;
//The runEventLoop is always true
while (runEventLoop) {
try {
//This is always false
if (!display.readAndDispatch()) {
getAdvisor().eventLoopIdle(display);
} catch (Throwable t) {
handler.handleException(t);
// In case Display was closed under us
if (display.isDisposed())
runEventLoop = false;
Is this behavior normal?
Hardy
Re: Can't update TableViewer when Button is pressed [message #329506 is a reply to message #329505] Thu, 26 June 2008 07:00 Go to previous message
This is the standard event loop and totally correct your problem is that
you are having a NPE somewhere in your code. So do NOT step through your
code with the debugger! Set a Debugger-Rule for NPE and run your program
in debug mode, once more there are NO breakpoints in your code!
To setup such a Exception-Rule simply click on the NPE in your console
you eclipse will lead you through.
Your stacktrace from before tells us that the NPE is so extract
everything into local vars and check what which one is NULL.
Tom
>> NullPointerException rule this way you can run your code with any
>> break points and can jump right to the line the NPE occurred and
>> Tom
>> Hardy schrieb:
>>> Tom Schindl wrote:
>>>> My guess is that:
>>>> Tom
>>>> Hardy schrieb:
>>> I changed to
>>> itself also.
>>> regards,
>>> Hardy
> display) {
> try {
> Hardy
Previous Topic:Java returned: 13
Next Topic:Activating a plug-in
Current Time: Tue Jul 22 00:42:27 EDT 2025
Powered by FUDForum. Page generated in 0.05606 seconds
