Home » Eclipse Projects » Eclipse Platform » programmatically call Import->Existing projects into workspace
programmatically call Import->Existing projects into workspace [message #329461] Wed, 25 June 2008 06:26 Go to next message
Originally posted by: subs._nospam_consertum.com
I am trying to find a way to directly invoke the Import Projects page of
the Import wizard. I can invoke the Import wizard but I can't find a way
to programmatically select "Existing projects into workspace" and then
select Next. Is there a way to do this directly?
While we are on the subject, once opened, I'd like to pre-populate some
of the fields on the Import Projects page - is that possible too?
Derek
Re: programmatically call Import->Existing projects into workspace [message #329463 is a reply to message #329461] Wed, 25 June 2008 06:57 Go to previous messageGo to next message
Derek,
We use ImportOperation directly.
Derek wrote:
> of the Import wizard. I can invoke the Import wizard but I can't find
> a way to programmatically select "Existing projects into workspace"
> and then select Next. Is there a way to do this directly?
> some of the fields on the Import Projects page - is that possible too?
> Thanks
Re: programmatically call Import->Existing projects into workspace [message #329464 is a reply to message #329463] Wed, 25 June 2008 07:10 Go to previous messageGo to next message
Hi Ed,
Thanks for the tip. However, I'd like to usethe Import Project dialog UI
- I'm (effectively) trying to provide a shortcut.
Ed Merks wrote:
> Derek,
> Derek wrote:
>> Thanks
Derek
Re: programmatically call Import->Existing projects into workspace [message #329474 is a reply to message #329461] Wed, 25 June 2008 10:39 Go to previous messageGo to next message
Derek wrote:
I think the wizard class you want to create is
org.eclipse.ui.wizards.datatransfer.ExternalProjectImportWiz ard
You'll have to create a WizardDialog to contain it, too. Here is a
snippet of code that we use to do this for our own Wizards:
// Grab the selection out of the tree and convert it to a
// StructuredSelection for use by the wizard.
StructuredSelection currentSelection = null;
if (activeSelection != null && activeSelection instanceof TreeSelection) {
currentSelection = new StructuredSelection(((TreeSelection)
activeSelection).toArray());
// get the wizard from the child class.
IWorkbenchWizard wizard = constructWizard();
// Get the workbench and initialize, the wizard.
IWorkbench workbench = PlatformUI.getWorkbench();
wizard.init(workbench, currentSelection);
// Open the wizard dialog with the given wizard.
WizardDialog dialog = new
WizardDialog(workbench.getActiveWorkbenchWindow().getShell() , wizard);
dialog.open();
Re: programmatically call Import->Existing projects into workspace [message #329477 is a reply to message #329474] Wed, 25 June 2008 11:08 Go to previous messageGo to next message
Eric Rizzo wrote:
> Derek wrote:
> dialog.open();
Thanks Eric - is there anything special in constructWizard()?
Derek
Re: programmatically call Import->Existing projects into workspace [message #329483 is a reply to message #329477] Wed, 25 June 2008 16:12 Go to previous message
Derek wrote:
> Eric Rizzo wrote:
>> Derek wrote:
>>> Hi,
>> TreeSelection) {
>> dialog.open();
No, it is just an abstract method in the class that I pulled this from,
so that subclasses can control exactly what kind of wizard gets created.
In your case, you'd just need an instance of ExternalProjectImportWizard
(I think).
Eric
Previous Topic:Window Preferences General WebBrowser Use external web browser Parameters ignored?
Next Topic:Migrating Launch Configurations
Current Time: Tue Jul 22 00:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.05547 seconds
