programmatically call Import->Existing projects into workspace [message #329461] |
Wed, 25 June 2008 06:26  |
Originally posted by: subs._nospam_consertum.com
I am trying to find a way to directly invoke the Import Projects page of
the Import wizard. I can invoke the Import wizard but I can't find a way
to programmatically select "Existing projects into workspace" and then
select Next. Is there a way to do this directly?
While we are on the subject, once opened, I'd like to pre-populate some
of the fields on the Import Projects page - is that possible too?
Derek
Re: programmatically call Import->Existing projects into workspace [message #329483 is a reply to message #329477] |
Wed, 25 June 2008 16:12  |
Derek wrote:
> Eric Rizzo wrote:
>> Derek wrote:
>>> Hi,
>>> of the Import wizard. I can invoke the Import wizard but I can't find
>>> a way to programmatically select "Existing projects into workspace"
>>> and then select Next. Is there a way to do this directly?
>>> some of the fields on the Import Projects page - is that possible too?
>> I think the wizard class you want to create is
>> org.eclipse.ui.wizards.datatransfer.ExternalProjectImportWiz ard
>> You'll have to create a WizardDialog to contain it, too. Here is a
>> snippet of code that we use to do this for our own Wizards:
>> // Grab the selection out of the tree and convert it to a
>> // StructuredSelection for use by the wizard.
>> StructuredSelection currentSelection = null;
>> if (activeSelection != null && activeSelection instanceof
>> TreeSelection) {
>> currentSelection = new StructuredSelection(((TreeSelection)
>> activeSelection).toArray());
>> // get the wizard from the child class.
>> IWorkbenchWizard wizard = constructWizard();
>> // Get the workbench and initialize, the wizard.
>> IWorkbench workbench = PlatformUI.getWorkbench();
>> wizard.init(workbench, currentSelection);
>> // Open the wizard dialog with the given wizard.
>> WizardDialog dialog = new
>> WizardDialog(workbench.getActiveWorkbenchWindow().getShell() , wizard);
>> dialog.open();
> Thanks Eric - is there anything special in constructWizard()?
No, it is just an abstract method in the class that I pulled this from,
so that subclasses can control exactly what kind of wizard gets created.
In your case, you'd just need an instance of ExternalProjectImportWizard
(I think).
Eric
FUDForum. Page generated in 0.09557 seconds
