Home » Eclipse Projects » Eclipse Platform » Help search behavior
Help search behavior [message #329450] Tue, 24 June 2008 17:25 Go to next message
Originally posted by: gmf.klmusic.no
I choose Help->Help Contents, I enter a search keyword and I hit enter,
but nothing happens. Why do I have to use my mouse to click the go button?
I'd think that using the Enter key would be an option in normal UI
behavoir. Isn't it? Or should I open a Bugzilla?
BTW, I'm on Windows.
Knut
Re: Help search behavior [message #329451 is a reply to message #329450] Tue, 24 June 2008 21:37 Go to previous message
Originally posted by: nospam_kowalskilee.gmail.com
Are you on Windows Vista or XP? Or another Windows flavor?
I think this might be the same symptom as Bugzilla 236524:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236524
Target is 3.4.1.
Would you take a look and comment on that bug? Especially if you can
provide details on what build you're running.
Hope this helps,
Lee Anne
Knut L wrote:
> button? I'd think that using the Enter key would be an option in normal
> UI behavoir. Isn't it? Or should I open a Bugzilla?
> Best regards,
> Knut
Previous Topic:Re: Jface Databinding Validator not called
Next Topic:Vista Bug using Nebula CDatetime
Current Time: Fri Nov 07 09:03:06 EST 2025
Powered by FUDForum. Page generated in 0.04335 seconds
