Home » Eclipse Projects » Eclipse Platform » Delete a project from project explorer
Delete a project from project explorer [message #329441] Tue, 24 June 2008 10:55 Go to next message
Originally posted by: gaurav_tas.rediffmail.com
hello all,
i am using eclipse 3.3, I am working on project explorer functionality,
Currently what i am doing is when i create a project, and select the
project i populate the resources of project in a tree, but i am not able
to get events for add a new project or delete an existing project.
Is it possible that i catch the events of deletion and addition of
Iprojects. If yes what is the way of doing this.
Please give me some idea.
Thanks in advance
Gaurav
Re: Delete a project from project explorer [message #329444 is a reply to message #329441] Tue, 24 June 2008 12:36 Go to previous messageGo to next message
You have to implement IResourceChangeListener and add it to IWorkspace
- Prakash
www.eclipse-tips.com
gaurav bhargav wrote:
> hello all,
> Thanks in advance
> Regards
> Gaurav
Re: Delete a project from project explorer [message #329454 is a reply to message #329444] Wed, 25 June 2008 01:59 Go to previous messageGo to next message
thanks prakash,
but i already add resourcelistener, and when i add or delete its fire
but i can not identify with this which file is removed or added.
Is there any way so that i can identify which file is added or removed
from iproject.
Thanks in advance.
gaurav
Re: Delete a project from project explorer [message #329459 is a reply to message #329454] Wed, 25 June 2008 04:53 Go to previous message
The IResourceChangeEvent.getResource() or
IResourceChangeEvent.getResourceDelta() should help
To iterate thru the resource delta and find the resources, you may have
to implement IResourceDeltaVisitor
- Prakash
> thanks prakash,
> from iproject.
> Thanks in advance.
> Regards
> gaurav
Previous Topic:Unhandled event loop exception
Next Topic:decorator on tableviewer ...
Current Time: Sun Jul 13 19:33:35 EDT 2025
Powered by FUDForum. Page generated in 0.03430 seconds
