Home » Eclipse Projects » Eclipse Platform » Re: Jface Databinding Validator not called
Re: Jface Databinding Validator not called [message #329417] Mon, 23 June 2008 12:59 Go to next message
Julien wrote:
> Hello,
> I'm using Jface databinding in eclipse 3.3 and I have an issue using
> Jface databinding. I'm using a validator to simulate the read only
> status. When the user try to change a value in a widget, the validator
> is called and the value from the model is set to the widget. The problem
> is that the validator is not called each time when i press the Keyboard
> Delete key(Maybe others). I've modified the hello world databinding
> Snippet to illustrate the problem. Just press Delete a few times and you
> will reproduct the behavior i've explained.
> Am I doing something wrong or is it a bug?
First: DataBinding is supported on the eclipse.platform newsgroup, so
you will get a better response if post there in the future. Be sure to
put "[DataBinding]" at the beginning of the subject line to help us
notice your question. I've copied eclipse.platform to this reply.
As for your question, why don't you make the widget read-only instead of
relying on DataBinding to enforce it?
Eric
Re: Jface Databinding Validator not called [message #329433 is a reply to message #329417] Tue, 24 June 2008 04:25 Go to previous messageGo to next message
Originally posted by: jdenet.sodifrance.fr
Eric Rizzo a écrit :
> Julien wrote:
>> Hello,
>> problem is that the validator is not called each time when i press the
>> Keyboard Delete key(Maybe others). I've modified the hello world
>> databinding Snippet to illustrate the problem. Just press Delete a few
>> times and you will reproduct the behavior i've explained.
> Eric
Thanks Eric,
Text Widgets can be set to readonly by using setEditable(false) but
CCombos setEditable(false) allow the user to select a value in the
combo. The setEnabled method don't meet my requirements because the user
loose tooltip and copy/Paste/Select actions on the widget. This is why
I'm trying to use a validator to reflect a readOnly status.
Julien
Re: Jface Databinding Validator not called [message #329447 is a reply to message #329433] Tue, 24 June 2008 15:46 Go to previous message
>> Julien wrote:
>>> Hello,
>>> validator is called and the value from the model is set to the
>>> widget. The problem is that the validator is not called each time
>>> when i press the Keyboard Delete key(Maybe others). I've modified the
>>> hello world databinding Snippet to illustrate the problem. Just press
>>> Delete a few times and you will reproduct the behavior i've explained.
>> to put "[DataBinding]" at the beginning of the subject line to help us
>> of relying on DataBinding to enforce it?
>> Eric
> Thanks Eric,
> Best regards,
> Julien
Julien,
CCombo.setEditable applies to editing of the text field, not to the
drop-down selection. I think that setEnabled() is the only way of
disabling the drop-down in SWT.
I suggest either:
* Use a Text instead of CCombo
* Submit a request for new API on CCombo supporting what you're asking
for, or
* Live with the inconveniences of CCombo.setEnabled(false).
Without knowing more about your program's interface it's hard to make a
better suggestion. I suspect there's another way to tackle this problem
by tweaking the UI. Maybe introduce a button that copies the CCombo's
text to the clipboard?
Matthew
Previous Topic:Re: Busy Section
Next Topic:Help search behavior
Current Time: Fri Jul 18 04:26:53 EDT 2025
Powered by FUDForum. Page generated in 0.08179 seconds
