Home » Eclipse Projects » Eclipse Platform » Programmatically invoking a cheat sheet
Programmatically invoking a cheat sheet [message #329412] Mon, 23 June 2008 10:43 Go to next message
I'm trying to display a certain cheat sheet as one of the tasks for a
pop-up action. The org.eclipse.ui.cheatsheet.OpenCheatSheetAction seems
to be what I need. But I'm not sure how to invoke it.
I figured it should be run asynchronously from my action-delegate so I
wrapped its invocation in a Job class invocation. The code in the job is:
String cheatSheetId = "com.myplugin.cheatsheet";
OpenCheatSheetAction action = new OpenCheatSheetAction(cheatSheetId);
action.run();
return Status.OK_STATUS;
But this yields me a NullPointerException:
!ENTRY org.eclipse.core.jobs 4 2 2008-06-23 07:22:29.686
!MESSAGE An internal error occurred during: "CheatSheetJob".
!STACK 0
org.eclipse.ui.cheatsheets.OpenCheatSheetAction.run(OpenChea tSheetAction.java:87)
treewizard.popup.actions.PopupWizard$CheatSheetJob.run(Popup Wizard.java:59)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Can someone point me into the proper direction for such an invocation.
Perhaps Jobs are not the way to go here.
- Paul
Re: Programmatically invoking a cheat sheet [message #329416 is a reply to message #329412] Mon, 23 June 2008 11:12 Go to previous messageGo to next message
I meant to also ask for direction on how to invoke an action in general.
Various tutorials show us how to create actions to be invoked by the
workbench. But my questions seems to be a special case of how actions
should be invoked programmatically by other plug-ins.
- Paul
Re: Programmatically invoking a cheat sheet [message #329426 is a reply to message #329412] Mon, 23 June 2008 13:58 Go to previous messageGo to next message
Commands are set up to be invoked programmatically ... although I'll
point out in this case, it seems like cheatsheets should be invoked on
the UI thread.
org.eclipse.ui.cheatsheets.openCheatSheet is the command and it takes a
parameter of cheatSheetId
Check out the Platform_Command_Framework for some general information on
invoking commands+handlers.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Programmatically invoking a cheat sheet [message #329453 is a reply to message #329426] Tue, 24 June 2008 22:36 Go to previous messageGo to next message
Hi Paul,
Thanks for the Eclipse Command info. I think I get it conceptually.
But how did you learn about the openCheatSheet command you mention? Are
available commands documented somewhere? I couldn't locate such a list
in either the Javadoc nor the plug-in extension docs. I was able to
find the command declared in the plugin.xml of the
org.eclipse.ui.cheatsheets plug-in once I knew what to look for (after
reading your post and links). Is this the usual way one determines
commands implemented by a plug-in?
Thanks for getting me started,
- Paul
> the UI thread.
> PW
Re: Programmatically invoking a cheat sheet [message #329473 is a reply to message #329453] Wed, 25 June 2008 10:23 Go to previous message
Paul Glezen wrote:
> Hi Paul,
> Thanks for the Eclipse Command info. I think I get it conceptually. But
To find a list of commands, you can either browse through the Keys
preference page (Window>Preferences>General>Keys) or look in the Plug-in
Registry View (which works great in 3.4).
I often have a quick look in Keys, which provides names and then use
that to look up the IDs in the Plug-in Registry View.
There are a couple of other ways to do it as well.
PW
Paul Webster
Previous Topic:Dynamically changing state of menus and toolbuttons
Next Topic:Programmatically finding references to extension points in the workspace
Current Time: Sun Aug 31 09:10:29 EDT 2025
Powered by FUDForum. Page generated in 0.03856 seconds
