Enhancement: "Open Type" working sets [message #329403] |
Mon, 23 June 2008 08:42  |
I'm sure this is a common pain point for anyone who actively works with
several branches of the same project.
It would be great if there were a Working Set option in the "Open Type"
and "Open Resource" dialog to essentially "follow" what was set in the
Package Explorer. Instead of having to manually change this option each
time I switch branches/working sets, the dialogs would be smart enough to
know which context I'm working in.
Currently, if I am working with WorkingSet_A and switch to WorkingSet_B, I
have to go in and change the working set of my "Open Type/Resource"
dialogs and then switch them back whenever I switch to Set_C or back to
Set_A.
The current "Window Working Set" option in the "Open Type" dialog sets the
context to be my entire workspace. This is unusable as an option because
there will be 3+ versions (diff branches) of the same classes as I type in
the class name.
Any chance we can get this enhancement added to a future release?
Re: Enhancement: "Open Type" working sets [message #329419 is a reply to message #329411] |
Mon, 23 June 2008 13:02  |
Takeshi Toyohara wrote:
> Eric Rizzo wrote:
>> Did you ever set your WWS from the main Window menu? It sounds like
>> you did not, since it is including your entire workspace (which is the
>> default behavior if there is no WWS specified).
> Ah. I was switching contexts using the small down arrow/triangle (hover
> text says "Menu") on the Package Explorer menu bar (next to the "Link
> with Editor" button), rather than using the Window->Working Sets menu.
> Thanks - selecting a working set from the Window->Working Sets menu
> provided the behavior I was looking for.
> Do you know if there is a way to have a one click switch for the WWS
> rather than having to de-select the current one, similar to selecting
> the WWS via the "Menu" menu, as I was doing previously?
No, because you can select any number of working sets to be included in
the WWS - it is not a mutually exclusive choice.
Eric
FUDForum. Page generated in 0.05695 seconds
